[Qgis-user] diffent feature to same attribute
Andrea Peri
aperi2007 at gmail.com
Sat Aug 24 09:26:04 PDT 2013
Perhaps I don't understand you rneed.
However I guess you could
use a postgis or, if you not quite smart with dbms , a spatialite.
Define a table with three geometries (geom, point and line),
and define a trigger.
After this you can edit the polygon geometries with qgis.
And when you commit the edit , the trigger will transfer transforming the
geometry in the line and point.
Is this what you need ?
Regards,
Andrea.
2013/8/23 Johan Nilsson <joni8135 at gmail.com>
> Looking fore a smart work flow..
> According to ESRI-shape-file specification you may have only one type of
> feature object; point, polyline och polygone in one layer. But how are the
> best way to have all tree feature types in one layer? The feature are in
> progress, so there no polygones are digitalized, the are a point.
> They have all the same attribute-data, except maybe feature-type....
> /Cheers
> Qgis-user mailing list
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130824/0c35eeea/attachment.html>
