[Qgis-user] Feature Discussion
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Wed Aug 28 06:56:04 PDT 2013
> Will you be at the QGIS developer meeting?
I can't speak for Steve, but if you weren't aware, you are both set to
present at the UK QGIS User group it seems; I'd love to go but it's already
fully booked (I do have a colleague going though).
https://ukqgis.wordpress.com/
Jonathan
On 27 August 2013 12:30, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi Steven,
> So basically this would be a "shortcut". Rather than first having to
> load a table first into the layer tree it would be loaded and joined
> directly from another layer.
> Some remarks/questions:
> * For QGIS 2.0 it is too late. Feature freeze is in place. But something
> to consider in QGIS 2.1
> * Would this loaded table appear in the layer tree as a separate table
> or not?
> * If we do this, one should treat all formats equal. Any table should
> joinable/loadable in this way - not just txt/csv/spreadsheets.
> I don't have a strong opinion on it. It would be more convenient, but it
> is not on my own personal list of top priorities.
> Will you be at the QGIS developer meeting? Matthias Kuhn is working on
> new database relations functions. This means that the whole joining and
> relations will be enhanced in QGIS 2.1. If you can make it to the QGIS
> developer meeting you could join the discussion there - see
> http://hub.qgis.org/wiki/quantum-gis/10_QGIS_Developer_Meeting_in_Brighton_2013
> for more information. The Borough of Poole does not seem to far away
> from Brighton - maybe you can join us for a day?
> Andreas
> Am 27.08.2013 12:50, schrieb Steven Campbell:
> > Hi all
> > After a brief conversation with a couple of people on Twitter I was
> wondering what the community's thoughts were on the following:
> > Adding a button into Joins section/tab under Layer Properties that would
> enable a user to join a tabular dataset (csv, txt etc) to an existing layer
> in QGIS. You can do this at present, by first brining in a Delimited Text
> Layer and then running the join, but I think that adding this button would
> make it easier/quicker for a user to join tabular data in QGIS. I'd
> especially see this being useful with datasets that have a geographic
> reference column i.e. a postcode column, but no geospatial co-ordinate
> reference system (Easting and Northing). I would also add that this is a
> similar function to what is available in most commercial GIS packages...
> > I'd appreciate any comments/suggestions before raising as a feature
> request (if deemed a good idea!)
> > Thanks
> > Steve
> > Steve Campbell
> > GIS Manager
> > Corporate Strategy and Communications
> > Borough of Poole | Civic Centre | Poole BH15 2RU
> > Tel: 01202 633 362
> > Email: s.campbell at poole.gov.uk<mailto:s.campbell at poole.gov.uk>
> > Website:www.boroughofpoole.com<http://www.boroughofpoole.com/>
> > Think Green! Please Recycle
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130828/fd3f6579/attachment.html>
