[Qgis-user] SLD export problems using Qgis master
Yewondwossen Assefa
assefay at gmail.com
Wed Aug 28 21:24:03 PDT 2013
Hi all,
I was playing with the SLD export using the latest nightly builds and
come across a couple of issues.
My layer is a polygon layer styled using 2 fills (simple solid fill and
a simple fill with the Diagonal X fill style). The layer also display
label based on one of the attribute.
Exporting the style to SLD I run into this items (full sld export is
attached, as well as the equivalent qgis style):
1) The GraphicFill section seems to be wrong:
<se:GraphicFill>
<se:Graphic/>
<se:Mark>
<se:WellKnownName>x</se:WellKnownName>
<se:Stroke>
<se:SvgParameter
name="stroke">#0000ff</se:SvgParameter>
</se:Stroke>
</se:Mark>
</se:GraphicFill>
Looking at the SLD specs, I think the Mark element should be a child
of the Graphic element. Is this a correct assumption?
2) No TextSymbolizer exported
The SLD does not contain a TextSymbolizer. I believe this is part of
the feature request lists ( http://hub.qgis.org/issues/6414, but wanted
to make sure that the latest version of QGIS does not yet support
TextSymbolizers.
Thanks
regards,
Y. Assefa
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130829/12fc76d3/attachment.html>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130829/12fc76d3/attachment-0001.html>
Type: text/xml
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130829/12fc76d3/attachment.xml>
