[Qgis-user] Four band raster displaying funny
Andrew Harfoot
ajph at geodata.soton.ac.uk
Mon Dec 2 07:38:30 PST 2013
Hi Jonathan,
Is it possible that QGIS is using the infrared band as an alpha channel?
This might explain the whitening effect, especially in non-vegetated
areas. I would check the Layer properties Transparency tab to see
whether anything is set as the transparency band. If it is, you could
override QGIS by setting a default style.
Cheers,
Andy
On 02/12/2013 11:53, Jonathan Moules wrote:
> Hi List,
> I've got a 4 band raster aerial photography (RGBI) that comprises lots
> of tiles. I've merged some of the tiles together with:
> gdal_merge -o 1.tif -of GTiff -co TILED=YES -co BIGTIFF=YES -co
> COMPRESS=JPEG -co JPEG_QUALITY=50 -co BLOCKXSIZE=512 -co
> BLOCKYSIZE=512 --optfile tiff_list.txt
> But the resultant file looks funny in QGIS.
> This is what the source file looks like (correct):
> Inline images 1
> This is what the merged file looks like (wrong):
> Inline images 2
> All the shadows are a whitey colour. This doesn't happen with 3-band
> (RGB) images.
> I've tried comparing individual bands; they all look different in the
> 4-band.
> However, if I open the four-band in ArcGIS, it looks fine (both source
> and original).
> Anyone know what's going on? Is it a QGIS bug or is it doing something
> "smart"; I can't see anything odd going on with symbology.
> Thanks,
> Jonathan
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use
> it, or disclose it to anyone else. If you have received this
> transmission in error please notify the sender immediately. All email
> traffic sent to or from us, including without limitation all GCSX
> traffic, may be subject to recording and/or monitoring in accordance
> with relevant legislation.
> Qgis-user mailing list
Andy Harfoot
GeoData Institute
University of Southampton
Southampton
SO17 1BJ
Tel: +44 (0)23 8059 2719
Fax: +44 (0)23 8059 2849
www.geodata.soton.ac.uk
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131202/bdb4b11f/attachment.html>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131202/bdb4b11f/attachment.png>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131202/bdb4b11f/attachment-0001.png>
