[Qgis-user] Four band raster displaying funny
Andrew Harfoot
ajph at geodata.soton.ac.uk
Mon Dec 2 08:10:11 PST 2013
I think QGIS is innocent in this - if a band is set as an alpha channel
then it should be handled as such by default in a viewer (so mark down
Arc for not using the alpha information!).
GDAL is the culprit as it is adding the alpha interpretation without
being prompted. I have just replicated this with some RGBI imagery
myself: prior to passing through GDAL's hands the IR band is present,
but isn't interpreted as an alpha channel. I can't get the -setci switch
to do anything though :(
Cheers,
Andy
On 02/12/2013 16:00, Jonathan Moules wrote:
> Hi Andy,
> Yep, that was it. I didn't know QGIS could do that; another good
> example of software trying to be "smart" and confusing the poor user. :-)
> I didn't know gdalwarp could do mosaicing too. I'll have to test it.
> I'll ask on the gdal list if I want to try the -setci parameter.
> Many thanks!
> Jonathan
> On 2 December 2013 15:48, Andrew Harfoot <ajph at geodata.soton.ac.uk
> <mailto:ajph at geodata.soton.ac.uk>> wrote:
> PS. gdalwarp offers more flexibility when mosaicing rasters, and
> is better at memory management. I have just noticed that in GDAL
> 1.10 and above there is an gdalwarp option -setci that 'Sets the
> color interpretation of the bands of the target dataset from the
> source dataset'. This could be used to remove the assignment of
> the alpha channel to the IR band on merging. Sadly there isn't an
> example of its usage!
> Cheers,
> Andy
> On 02/12/2013 11:53, Jonathan Moules wrote:
>> Hi List,
>> I've got a 4 band raster aerial photography (RGBI) that comprises
>> lots of tiles. I've merged some of the tiles together with:
>> gdal_merge -o 1.tif -of GTiff -co TILED=YES -co BIGTIFF=YES
>> -co COMPRESS=JPEG -co JPEG_QUALITY=50 -co BLOCKXSIZE=512 -co
>> BLOCKYSIZE=512 --optfile tiff_list.txt
>> But the resultant file looks funny in QGIS.
>> This is what the source file looks like (correct):
>> Inline images 1
>> This is what the merged file looks like (wrong):
>> Inline images 2
>> All the shadows are a whitey colour. This doesn't happen with
>> 3-band (RGB) images.
>> I've tried comparing individual bands; they all look different in
>> the 4-band.
>> However, if I open the four-band in ArcGIS, it looks fine (both
>> source and original).
>> Anyone know what's going on? Is it a QGIS bug or is it doing
>> something "smart"; I can't see anything odd going on with symbology.
>> Thanks,
>> Jonathan
>> This transmission is intended for the named addressee(s) only and
>> may contain sensitive or protectively marked material up to
>> RESTRICTED and should be handled accordingly. Unless you are the
>> named addressee (or authorised to receive it for the addressee)
>> you may not copy or use it, or disclose it to anyone else. If you
>> have received this transmission in error please notify the sender
>> immediately. All email traffic sent to or from us, including
>> without limitation all GCSX traffic, may be subject to recording
>> and/or monitoring in accordance with relevant legislation.
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Andy Harfoot
> GeoData Institute
> University of Southampton
> Southampton
> SO17 1BJ
> Tel:+44 (0)23 8059 2719 <tel:%2B44%20%280%2923%208059%202719>
> Fax:+44 (0)23 8059 2849 <tel:%2B44%20%280%2923%208059%202849>
> www.geodata.soton.ac.uk <http://www.geodata.soton.ac.uk>
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use
> it, or disclose it to anyone else. If you have received this
> transmission in error please notify the sender immediately. All email
> traffic sent to or from us, including without limitation all GCSX
> traffic, may be subject to recording and/or monitoring in accordance
Andy Harfoot
GeoData Institute
Southampton
SO17 1BJ
Tel: +44 (0)23 8059 2719
Fax: +44 (0)23 8059 2849
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131202/f7b9207c/attachment.html>
