[Qgis-user] Qgis Web Client: another searchtable
Andreas Neumann
a.neumann at carto.net
Tue Dec 3 05:19:50 PST 2013
Hi Geert,
Am 03.12.2013 12:15, schrieb Geert Smet:
> Hi all,
> I have 2 questions about Qgis Web Client:
> 1) Is it's possible to use another searchtable (instead of the default) depending on the project you choice in the theme switcher and how can I do this ?
yes - see https://github.com/qgis/QGIS-Web-Client/blob/master/README
There is an URL parameter called "searchtables" which you can also
specify in GISProjectListing.js
> 2) Is it normal that 'WMS' is in the upper-level of the in the Map layers instead of the projectname ?
no - this shouldn't be. It was an error which should be corrected some
time ago. Please update to the latest version.
Andreas
