[Qgis-user] Error GRASS algorithms Processing Plugin
Luis Miguel Royo Perez
luis.miguel.royo at gmail.com
Tue Dec 3 06:16:52 PST 2013
I'm having similar problems withs some GRASS algorithms in processing
plugin.
On the one hand i have installed Ubuntu 12.04 with Qgis 2.0.1. In this
machine when I run/r.neighbors/algorithm don't make it and log output
says this:
ALGORITHM
processing.runalg("grass:r.neighbors","/home/user/Documents/Projects_GIS/Sgt/MDE-Sgt.asc",0,3,False,False,"","693360.0,698725.0,4331760.0,4336495.0",5,"/home/luismi/Documentos/Curso_Avanzado/testing/segmentacion/test34.tif")
but the courious thing is this... 11sec later it starts another
algorithm/v.voronoi/
* processing.runalg("grass:v.voronoi","/home/user/.qgis2/python/plugins/processing/tests/data/points.shp",False,False,"270778.60198,270855.745301,4458921.97814,4458983.8488",-1,0.0001,0,None)
And last/log messages/says this:
* Data Source is invalid()
On the other hand I'm using OSGeoLive to compare both software:
It happens the same trouble, the same two algorithm
runnign,/r.neighbors/, and spontaneously/v.voronoi/, but in this case
the log message is this:
* OGR[3] error 4: Unable to open
/usr/share/qgis/python/plugins/processing/tests/data/points.shp or
/usr/share/qgis/python/plugins/processing/tests/data/points.SHP.
Seems there is something wrong inside, but I don't know what is it...
any idea???
Thank you! :D
Luís Miguel Royo Pérez
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131203/8e8a69e2/attachment.html>
