[Qgis-user] MrSID raster and QGIS in linux
BigBaka
hunt.glenn at gmail.com
Wed Dec 4 01:50:17 PST 2013
I updated the dependencies line for libqscintilla2-9 to 2-8 and for
libboost1.48 instead of 1.53 as follows;
sudo apt-get install build-essential libgeos-dev libspatialite3
libspatialite-dev libcurl4-nss-dev byacc cmake cmake-gui ncurses-dev
bison gsl-bin libgsl0-dev libexpat1-dev libexpat1 libproj0 libproj-dev
libgeotiff2 libgeotiff-dev libwxgtk2.8-dev swig python-psycopg2
python-numpy python-qt4 python-qt4-dev python-sip python-sip-dev
python-wxgtk2.8 postgresql-server-dev-9.1 postgresql-client
postgresql-9.1 postgresql-contrib-9.1 curl unixodbc unixodbc-dev libkml0
libkml-dev proj-bin flex libpng12-0 libpng12-dev mesa-common-dev
freeglut3-dev tcl-dev tk8.5-dev libfftw3-3 libfftw3-dev libxmu-dev
libqt4-dev pyqt4-dev-tools libqwt-dev libspatialindex-dev
libopenjpeg-dev git subversion libcairo2-dev libpoppler-dev lzma
lzma-dev libboost1.48-all-dev ia32-libs-multiarch libqscintilla2-8
libqscintilla2-dev python-qscintilla2 opencl-headers libjasper-dev
Will see how I go now.
Thanks
On 04/12/13 16:16, Eric Goddard [via OSGeo.org] wrote:
> It sounds like you didn't get all of the packages in the dependencies
> section installed; many of the development packages should have been
> installed with the build-essential package. bison and ncurses-dev are
> also in the list and will take care of the curses error., and the
> libxmu-dev package will fix the X error. Did you paste the whole chunk
> of dependencies in as a single line?
> On Wed, Dec 4, 2013 at 3:04 AM, BigBaka <[hidden email]
> </user/SendEmail.jtp?type=node&node=5092596&i=0>> wrote:
> > Hi Eric,
> > Am I missing some compiling package? I also had to download a
> program called
> > bison. Now I getting an error Unable to locate curses. Also couldn't
> seem to
> > locate W11 and X. When I tried to install a package called curses.h
> it said
> > something about "package ncurses-hexedit should be rebuilt with new
> > debhelper to get trigger support! - whatever that means.
> > On 04/12/13 15:34, Eric Goddard [via OSGeo.org] wrote:
> > You will need to remove the --with-postgres=yes and
> > --with-postgres-includes=/usr/include/postgresql options. As for the
> > lex error, you should be able to fix that by running
> > sudo apt-get install flex
> > on the command line before configuring.
> > On Wed, Dec 4, 2013 at 1:42 AM, Glenn Hunt <[hidden email]> wrote:
> >> Hi Eric,
> >> I decided not to compile postgis but do I then need to change the
> >> configure
> >> line for compiling grass 64? I just tried to compile now using the
> full
> >> text
> >> in your document and got an error right at the beginning.
> >> checing for lex... no
> >> configure: error: *** Unable to locate lex.
> >> On 04/12/13 00:20, Eric Goddard wrote:
> >> The packages I use for postgres on Ubuntu 13.04 are:
> >> postgresql-server-dev-9.1 postgresql-client postgresql-9.1
> >> postgresql-contrib-9.1. I don't know if Ubuntu 12.04 has postgres 9.1;
> >> it may still be on 9. Try finding the equivalent packages with
> >> synaptic, or simply don't compile postgis if you never use it.
> >> On Tue, Dec 3, 2013 at 11:07 AM, BigBaka <[hidden email]> wrote:
> >> Re configured, make, and make installed gdal. Moved onto the postgis
> >> Downloaded package but when in tried to configure i got an error
> >> checking for pg_config... no
> >> configure: error: could not find pg_config within the current path.
> You
> >> may
> >> need to try re-running configure with a --with-pgconfig parameter.
> >> make: *** [GNUmakefile] Error 1
> >> ideas?
> >> On 03/12/13 23:26, Eric Goddard [via OSGeo.org] wrote:
> >> I would recompile gdal. Switch to the gdal source directory and run
> >> 'make clean', and then re run the ./configure, make, and make install
> >> lines.
> >> On Tue, Dec 3, 2013 at 10:21 AM, BigBaka <[hidden email]> wrote:
> >> After posting that I went into synaptic and installed geotiff 1.4.
> >> Following
> >> that it seems it worked.
> >> Values for GEOTIFF_INCLUDE_DIR and GEOTIFF_LIBRARY
> >> are usr/include/geotiff and usr/lib/libgeotiff.so respectively now.
> >> I did manage to get the gdal compiled without geotiff, but I'm not
> sure
> >> there may have been some errors that I just overlooked. Would you
> >> recommend
> >> starting from the beginning again, or just keep going as is?
> >> Regards,
> >> BB
> >> View this message in context:
> http://osgeo-org.1560.x6.nabble.com/MrSID-raster-and-QGIS-in-linux-tp5090885p5092439.html
> >> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> >> _______________________________________________
> >> Qgis-user mailing list
> >> [hidden email]
> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
> >> [hidden email]
> >> If you reply to this email, your message will be added to the
> discussion
> >> below:
> http://osgeo-org.1560.x6.nabble.com/MrSID-raster-and-QGIS-in-linux-tp5090885p5092441.html
> >> To unsubscribe from MrSID raster and QGIS in linux, click here.
> >> NAML
> >> View this message in context: Re: MrSID raster and QGIS in linux
> >> [hidden email]
> > [hidden email]
> discussion
> > below:
> http://osgeo-org.1560.x6.nabble.com/MrSID-raster-and-QGIS-in-linux-tp5090885p5092585.html
> > NAML
> > [hidden email] </user/SendEmail.jtp?type=node&node=5092596&i=1>
> [hidden email] </user/SendEmail.jtp?type=node&node=5092596&i=2>
> discussion below:
> http://osgeo-org.1560.x6.nabble.com/MrSID-raster-and-QGIS-in-linux-tp5090885p5092596.html
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5090885&code=aHVudC5nbGVubkBnbWFpbC5jb218NTA5MDg4NXwtMjA4MDk5NDE3MA==>.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/MrSID-raster-and-QGIS-in-linux-tp5090885p5092610.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131204/aa84748a/attachment.html>
