[Qgis-user] Error GRASS algorithms Processing Plugin
Victor Olaya volayaf at gmail.com
Wed Dec 4 04:53:46 PST 2013
Luis
That's not the problem. If you read in the error message, it says
something like "a test has been performed to check that GRASS is
installed". That test is done running v.voronoi on a sample layer that
is included with processing. If it works fine, it means that GRASS is
correctly installed and wroking fine from Processing.
It seems that it cannot open that sample layer, Maybe due to acess
permissions not being enough on that folder? But it would be strange,
since the actual plugin is being read from that same folder...
Cheers
2013/12/4 luismi_2 <luis.miguel.royo at gmail.com>:
> I've installed a Virtual Machine with Lubuntu 12.04. I've tried to make a
> fresh installation, and happend the same, *v.voronoi* is running
> spontaneously... I think that's the problem...
> Any help? Please!!!
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Error-GRASS-algorithms-Processing-Plugin-tp5092407p5092627.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
