[Qgis-user] Change field for vector style
Carlos Cerdán
sig.upagu at gmail.com
Wed Dec 4 07:22:22 PST 2013
Hi all, specially developers
QGIS 2.0.1 is great! I'm using it every day at work and i'm doing something
frecuently, that i'd like help me to automatize:
1. There is a vector layer with style defined by a field.
2. Add another vector layer with same style, but defined by another field.
3. Copy style from layer 1 to layer 2: categories-values are copied, but as
the name field is not same, layer 2 gets white, so i have to select the
correct field... BUT, a problem: defined colors go out, so i have to define
them again.
Request: Next version Could consider change field (in this situation)
without lose the style? Or there is some way to do it in 2.0.1 (on Ubuntu
12.04)?
Anxiously
Carlos
PD. I know it: i have to change name of fields in both two layers to
same... but it is not an option in this case.
PPD Sorry if my English is bad.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131204/9b11c348/attachment.html>
