[Qgis-user] Data defined color
David J. Bakeman
dbakeman at comcast.net
Thu Dec 5 13:12:06 PST 2013
On 12/05/2013 12:41 PM, Goyo wrote:
> 2013/12/5 David J. Bakeman <dbakeman at comcast.net>:
>> On 12/05/2013 11:09 AM, Goyo wrote:
>>> Works for me with the latest development build available for ubuntu 13.10.
>> When you say it works can you give details? I haven't been able to get
>> anything to work even a point shapefile.
> I think it would be better if you give details on what exactly you are
> doing and does not work. Find attached a sample project with a polygon
> shapefile styled with data driven colors. Does it work for you?
Yes it does and that gave me the clue. I had not realized that there
was a column of check boxes at the left or that I needed to check the
color box to get it to be used. Ounce I did that everything worked as
expected.
Thanks a bunch.
> Goyo
