[Qgis-user] No data value in Raster Merge not working
    Etienne Tourigny
    etourigny.dev at gmail.com
    Fri Dec  6 11:30:36 PST 2013
In the window there is a box with the actual command used internally (at
the bottom, just below "Load into canvas when finished)", it is easy to
modify it after clicking the pencil button.
If you want this changed in future versions please test.
Etienne
On Fri, Dec 6, 2013 at 5:01 PM, Harish <harry.om2000 at gmail.com> wrote:
> I do not use commands/scripts in QGIS. I use only options available in
> corresponding window, there the option is available, which is not providing
> the desired output. But the same option in clipper window is giving correct
> results.
> Regards
> <http://www.nird.org.in>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131206/866091ea/attachment.html>
