[Qgis-user] Export/Import a list of values from a qml file
    Ramon Andiñach
    custard at westnet.com.au
    Sun Dec  8 13:59:38 PST 2013
Last time I needed to extract that data I did a little awk script.
https://www.dropbox.com/s/k5ca7ox5f796pa0/CodeExtract.awk
If you use it as "awk -f CodeExtract.awk input_file > output_file" it should give you a csv with the symbol code (which is helpful for what I was doing), value, and description.
I don't have windows just at the minute to check with, but if you run it from the OSGeo Shell that was installed with QGIS it should work fine. I'll check when I get into work.
I don't use databases normally, so I'm not sure what you would need to do for that bit.
-ramon.
On 08/12/2013, at 16:59 , Andrea Peri wrote:
> Hi,
> I have a qml file that describe a category rendering with a huge list of domains.
> I like to extract it to import it in a DB. I'm interesting to import anly the value and its description, no interest for color,outline and so on.
> There is some code available capable to do this ?
> Thx
> Andrea Peri
> qwerty àèìòù
> Qgis-user mailing list
