[Qgis-user] Problems with svg symbols on qgis server
Jan Michálek
godzilalalala at gmail.com
Mon Dec 9 13:48:51 PST 2013
We have it on the Gentoo (I`m not sure, but i think, that we have newest
version - 2), i tried all logical posibilities of placing svg files,
absolute path in qgs file etc. With the svg files placed in
/usr/share/qgis/svg, just like on my arch linux desktop it doesn`t work.
Maybe it is rules issue (im not admin of this server), but xserver didn`t
run on our server with high probability, it is only web server.
This script I found in old mailing lists.
Server didn`t crash, my polygons are returned without fill.
I will ask our admin to run xserver and will see.
Thanks Je;
2013/12/9 Andreas Neumann <a.neumann at carto.net>
> Hi,
> On what operating system are you and what version are you using?
> It seems to be a path-issue and not an X-Server issue. If it was an
> X-Server issue your QGIS server would just crash - but it looks like
> your maps are drawn, but without SVG symbols. Did you try to copy the
> SVG symbols to a path where the standard SVG symbols are located? E.g.
> /usr/local/share/qgis/svg on Linux?
> Regarding XServer: I use the package "vnc4server" on my Ubuntu Server
> along with a small start-script I got from Jürgen. Let me know if you
> need this.
> Andreas
> Am 09.12.2013 21:11, schrieb Leknín Řepánek:
> > Good evening
> > I have a problem with using svg polygon fill on qgis server. My polygons
> > aren`t filled. I tried absolute path (in my desktop solution I`m
> > changing svg symbol using table variable). Relative path to qgis project
> > location and original qgis svg location. Nothing isn`t working for me. I
> > found in older posts on this list, i need running xserver on server with
> > qgis server (so much servers :D), but it is old post and I don`t know,
> > if I actually need this on this new version.
> > Our server works on gentoo.
> > Thanks Je;
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131209/1392e528/attachment.html>
