[Qgis-user] Open and read shapefile plugin in QGIS dufour
Suryo Miles
suryomiles666 at gmail.com
Tue Dec 10 08:51:41 PST 2013
I try to make plugin to read shapefile with plugin builder in QGIS and i
try to import pyshp in plugin to read shapefiles but i got this error
message
File "C:\Users\Mr.Pakde/.qgis2/python/plugins\shpread\shpreaddialog.py",
line 42, in baca
shapefile.Reader("shapefiles/blockgroups")
File "C:\Users\Mr.Pakde/.qgis2/python/plugins\shpread\shapefile.py", line
220, in __init__
self.load(args[0])
253, in load
raise ShapefileException("Unable to open %s.shp" % shapeName)
ShapefileException: Unable to open shapefiles/blockgroups.shp
Python version:
2.7.4 (default, Apr 6 2013, 19:54:46) [MSC v.1500 32 bit (Intel)]
------and this is code i use ( i put it in dialog.py)-------
# insert every signal connection here!
cariButton = self.ui.btnShp
QtCore.QObject.connect(cariButton,
QtCore.SIGNAL('clicked()'),self.baca)
def baca(self):
sf = QtGui.QFileDialog.getOpenFileName(self, 'Open File', '*.shp')
shapes = sf.shapes()
# Read the bounding box from the 4th shape
shapes[3].bbox
[-122.485792, 37.786931000000003, -122.446285, 37.811019000000002]
# Read the 8th point in the 4th shape
shapes[3].points[7]
[-122.471063, 37.787402999999998]
#panggil isi data
self.isiDataFile(sf)
def isiDataFile(self, nmfile):
#buka dengan open mode baca
teksFile = open(nmfile, 'r').read()
self.ui.textShp.setText(teksFile)
can someone help me?
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131210/5c382c29/attachment.html>
