[Qgis-user] Menu Customisation
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Wed Dec 11 03:44:38 PST 2013
Hi List,
  Does menu customisation work? As in Settings-> Customisation?
I've tried several times now to customise menus (i.e., by removing the
Oracle Raster from the "mLayerMenu"), but nothing happens. So I try
restarting QGIS, but then the next time it opens the item is checked again.
Am I doing something wrong?
Also, where are these changes saved? The registry (this is Windows)?
Thanks,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131211/a1e56d24/attachment.html>
