[Qgis-user] WMS layer not working in QGIS
    Jonathan Moules
    jonathanmoules at warwickshire.gov.uk
    Wed Dec 11 05:46:25 PST 2013
Hi All,
Thanks for all the replies.
The consensus is that the service is a bit broken. I'll try telling the
Land Registry about it, but based on their dismissive comments on the board
that Thomas linked to, I'm not convinced that'll get anywhere.
I've also opened a QGIS feature request (http://hub.qgis.org/issues/9197)
that it ignore bad URL's.
Hopefully one of these two tacks will result in our being able to use the
service.
Cheers,
Jonathan
On 11 December 2013 13:11, Graham <gford2113 at outlook.com> wrote:
> Hi Jonathan,
> What a coincidence!  I tried to access the Land Registry wms yesterday as
> well - and had no success.  (I'm using version 2.0.1 - Dufour running in
> Windows XP Pro)
> The wms connects OK and gives me a choice of two layers:
> Inspire:CP.CadastralParcel
> Inspire_common:DEFAULT
> Whichever layer I choose, the result is the same.  The layer appears in the
> layer panel, but nothing displays on the map - even when zoomed in to, say
> 1:1,000.  When I pan the map the status bar reports 'getting map via WMS'
> and then reports '3939 of 3939 bytes of map downloaded.
> The error message is:
> Map request error (Status: 200; Response: �PNG
> ; Content-Type: ;
> URL:
> http://inspire.landregistry.gov.uk/inspire/ows?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=-1.54320498923281058,56.16644864901333989,-0.93651227790715641,56.44164010340207227&CRS=CRS:84&WIDTH=668&HEIGHT=303&LAYERS=inspire:CP.CadastralParcel&STYLES=&FORMAT=image/png&DPI=96&MAP_RESOLUTION=96&FORMAT_OPTIONS=dpi:96&TRANSPARENT=TRUE
> Cheers
> Graham
> http://osgeo-org.1560.x6.nabble.com/WMS-layer-not-working-in-QGIS-tp5093606p5093750.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131211/0090a0ec/attachment.html>
