[Qgis-user] Newbieish - save layer as DXF
Andreas Neumann
a.neumann at carto.net
Sun Dec 15 13:29:53 PST 2013
Hi Hugh,
DXF Export is not fully supported in QGIS 2.0 (you discovered that
already) - you will have to wait for QGIS 2.2 which will probably be
released in February 2014.
Some improvements are already in QGIS master (2.1), but the labels are
not yet supported. Marco Hugentobler is working on it.
Andreas
Am 15.12.2013 21:17, schrieb h:
> Hi,
> I am needing to convert a shp file (lines) to dxf. I have been using the
> shp file in qgis very successfully.
> What I would like to do is save a layer as dxf. I have done this
> through the "layers" window, but I am only getting raw lines, whereas I
> would like to also get the labels.
> In qgis can I export / save to DXF and get labels (I would also
> like symbols for some point layers) to also be exported?
> TIA
> Hugh
> Qgis-user mailing list
