[Qgis-user] QGIS Oracle support
Andreas Bergmann bergmann.hh at gmail.com
Mon Dec 16 07:17:09 PST 2013
I try to use the Oracle Plugin of QGIS (2.0.1).
I created a table mit a geometry and added geom_metadata and a spatial
index.
Then I created a view for the same table and added proper meta data in
user_sdo_geom_metadata
too.
In the resource browser I open the Oracle db, navigate to the view and add
the layer , I get the message that the view cannot be used since it is
invalid.
*The layer dbname='oradb' host=localhost port=1521 user='gisdb'
password='xxx' key='THE_GEOM' srid=4326 type=MULTIPOLYGON
table="GISDB"."VIEW1" (THE_GEOM) sql= is not a valid layer and can not be
added to the map*
Is there a chance to use Oracle Views with Geometry in QGIS?
-Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131216/02cce1fa/attachment.html>
