[Qgis-user] 3D dxf files
Matt Boyd
mattslists at gmail.com
Mon Dec 16 17:13:17 PST 2013
I don't get anything more than
gawk -f 3dface2csv tokaj.dxf
id;layer;wkt
there are 3DFACES in that file, wondering if it's a codepage thing?
thanks
On Mon, Dec 16, 2013 at 6:37 PM, Siki Zoltan <siki at agt.bme.hu> wrote:
> Dear Matt,
> are there any 3DFACE entities in you dxf file?
> You can check it opening the dxf file with a text editor program.
> This gawk script works only with 3DFACEs, if no such entity in the input,
> you get the header only.
> You can download a smaple dxf file (a smaller one then yours) and the
> result of the conversion from here:
> http://www.agt.bme.hu/siki/tokaj.dxf
> http://www.agt.bme.hu/siki/tokaj.csv
> I used the following command:
> gawk -f 3dface2csv.awk tokaj.dxf > tokaj.csv
> Load the csv file into QGIS as Delimited text layer, don't forget to
> change the delimiter character to semicolon and the wkt column.
> Best regards,
> Zoltan
>> On Mon, 16 Dec 2013, Matt Boyd wrote:
>> Hi Zoltan,
>>> the script looks fine to me however, all I get in the output is
>>> id;layer;wkt
>>> any thoughts on what I'm not seeing?
>>> Thanks
>>> On Mon, Dec 16, 2013 at 10:19 AM, Matt Boyd <mattslists at gmail.com>
>>> wrote:
>>> Wow,
>>>> thanks Zoltan, I just saw this email this morning and this is exactly
>>>> what
>>>> I was thinking I'd have to do myself.
>>>> I did manage to get SAGA to load the dxf, however I'd only made it as
>>>> far
>>>> as being able to apply a value to each polygon, not each node.
>>>> I'll get onto this now.
>>>> Many thanks and much appreciation.
>>>> Matt
>>>> On Fri, Dec 13, 2013 at 6:57 AM, Siki Zoltan <siki at agt.bme.hu> wrote:
>>>> Dear Matt,
>>>>> I've written an awk script to convert 3DFACE-s form dxf to a delimited
>>>>> text file. Please find attached.
>>>>> If you use Linux, start it in the shell like:
>>>>> gawk -f 3dface2csv.awk Otway_Basin_Granites-gravity.dxf > result.csv
>>>>> You can load the result.csv into QGIS az a delimited text layer with
>>>>> WKT
>>>>> column.
>>>>> Regards,
>>>>> Zoltan
>>>>> On Wed, 11 Dec 2013, Siki Zoltan wrote:
>>>>> Dear Matt,
>>>>>> I've tested your dxf files in QGIS 2.0
>>>>>> Otway_Basin_curves.dxf loaded successfully (2D polylines)
>>>>>> Otway_Basin_Faults-basin.dxf not loaded, 3D faces are not suported by
>>>>>> GDAL DXF driver
>>>>>> Otway_Basin_Faults-shallow.dxf not loaded 3D faces
>>>>>> Otway_Basin_Granites-magnetics.dxf not loaded 3D faces
>>>>>> Otway_Basin_Granites-gravity.dxf not loaded 3D faces
>>>>>> You should find another way to import 3D faces from a dxf file.
>>>>>> Regards,
>>>>>> Zoltan
>>>>>> On Wed, 11 Dec 2013, Matt Boyd wrote:
>>>>>> I'll give ogr2ogr a shot.
>>>>>>> woops, sorry wrong link I meant this one
>>>>>>> http://er-info.dpi.vic.gov.au/cgi-bin/download.pl?ID=3D_
>>>>>>> models/t009_OtwayBasin_3D_dxf.zip
>>>>>>> On Tue, Dec 10, 2013 at 6:02 PM, Siki Zoltan <siki at agt.bme.hu>
>>>>>>> wrote:
>>>>>>> Dear Matt,
>>>>>>>> which version did you try?
>>>>>>>> What type of entites your dxf file(s) contains? Are them supported
>>>>>>>> by
>>>>>>>> ogr
>>>>>>>> DXF driver? Check http://www.gdal.org/ogr/drv_dxf.html
>>>>>>>> Try to check entities with ogrinfo.
>>>>>>>> I had trouble with 1.8 (exspecially on Windows) to load dxf.
>>>>>>>> I used ogr2ogr instead QGIS, because you can set more options.
>>>>>>>> I cannot find any DXf file in the zip file you specify.
>>>>>>>> Best regards,
>>>>>>>> Zoltan
>>>>>>>> On Tue, 10 Dec 2013, Matt Boyd wrote:
>>>>>>>> Hi group,
>>>>>>>> I'm trying to make sense of some DXF files.
>>>>>>>>> these ones in particular
>>>>>>>>> models/3D_model_attributes.zip
>>>>>>>>> there's also a 3D pdf model here..
>>>>>>>>> models/t009_OtwayBasin_3D.pdf
>>>>>>>>> QGIS isn't able to open the dxf files, or it does but all I see is
>>>>>>>>> an
>>>>>>>>> icon
>>>>>>>>> called "entities" with no attributes. Ideally I'd be able to load
>>>>>>>>> these as
>>>>>>>>> rasters and make a few maps.
>>>>>>>>> Any ideas?
>>>>>>>>> thanks
>>>>>>>>> matt
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131217/5df19d8e/attachment.html>
