[Qgis-user] Weekly builds and JP2 files
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Wed Dec 18 04:20:31 PST 2013
Hi Jukka,
I'm only seeing the JP2OpenJPEG in there (this is for the weeklies, I've
uninstalled my 2.0 so can't check that).
So I guess given the behaviour/speed difference that 2.0 comes with the
JP2ECW driver? Would it be much effort to add to the weeklies? Or is there
a way to for me to easily add it post-install?
Thanks,
Jonathan
On 17 December 2013 19:47, Jukka Rahkonen <jukka.rahkonen at mmmtike.fi> wrote:
> Jonathan Moules <jonathanmoules at ...> writes:
> > Anyone?
> > On 11 December 2013 17:04, Jonathan Moules
> <jonathanmoules at warwickshire.gov.uk> wrote:
> > Hi List,
> > A question about the weekly builds (www.qgis.org/downloads/weekly). They
> seem to struggle with loading JP2 files using the usual raster dialog.
> First
> they're incredibly slow, but on top of that when they do load they tend to
> be some sort of horrible mess of lots of black of random colours in a
> griddish pattern or similar.
> > Do the weekly builds not include a functional JP2 reader? The same
> rasters
> work just fine in the stable release 2.0.1.
> Hi,
> Check what drivers are baked into GDAL. In Windows you can go to QGIS
> Dufour
> directory, set the environment by running osgeo4w.bat and then you can list
> the JP2 drivers as
> C:\Program Files\QGIS Dufour>gdal_translate --formats |find "JP2"
> JP2ECW (rov): ERDAS JPEG2000 (SDK 5.0)
> JP2OpenJPEG (rwv): JPEG-2000 driver based on OpenJPEG library
> JP2ECW is fast and JP2OpenJPEG is sometimes almost usable. JP2KAK is very
> good but that you can't get without Kakadu license. JP2MrSID used to be
> fast
> also but I do not know what is the status with the license.
> If there are several drivers for JPEG2000 GDAL is using the first on the
> list. You can skip a driver by setting GDAL_SKIP environment. Thus, if I
> would like to have a try with JP2OpenJPEG I should run SET GDAL_SKIP=JP2ECW
> first. No idea really how and where I should do it so that QGIS starts with
> that setting.
> -Jukka Rahkonen-
> Qgis-user mailing list
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131218/999f307e/attachment.html>
