[Qgis-user] Database error?? after installing qgis
Ramon AndiƱach custard at westnet.com.au
Fri Dec 20 19:11:36 PST 2013
On 20/12/2013, at 21:54 , anzgarone wrote:
> Hi List,
> i have a problem, after installing Qgis via ubuntugis (Ubuntu 12.04.; 64
> Bit, qgis 2.0.1 dufour).
> When i try to  start QGIS the following error turns up:
> http://hub.qgis.org/issues/8613 <http://hub.qgis.org/issues/8613>   the only
> difference: i work with ubuntu 12.04
> If i cancel the error massages Qgis runs and seems to work.
> But whats the Problem an how can i get rid of it?
> The suggestion in the link - to start qgis in the terminal - brings up the
> same error with and without "sudo".
That issue says that the .qgis2 folder has incorrectly set permissions.
The work-around in the ticket says delete the .qgis2 folder first;
then run qgis from the command line.
This should recreate .qgis2 with proper permissions.
Another way to tell if it worked, is that you'll have to reinstall your plugins.
-ramon.
You could rename .qgis2 to something else and get the same effect.
