[Qgis-user] Split polygon using area and DEM
Victor Olaya
volayaf at gmail.com
Fri Feb 1 01:06:56 PST 2013
> Many many thanks for your help on this matter. I have generated a harvesting
> plan using contours and buffers in a similar way to the method you proposed.
> I will however use your method in the future as it appears to be a little
> more semi-automated when compared to my approach.
If you know a bit of python, it can even be more automated, putting
all the calculations in the code.
> A quick question, if I use your method and want to split up each contour
> such that its size is around 5 ha, would I be able to do this using an
> 'out-of-the-box' module in sexxtante?
Sure, just run the same technique (which uses just plain modules,
nothing created specifically for that example) with different area
values
Regards
Victor
