[Qgis-user] QGIS and Python
Carsten Hogertz carsten.hogertz at gmail.com
Mon Feb 4 04:56:12 PST 2013
Well, I deleted everything in the mentioned folder. But without any result.
Do I have to delete it in other paths aswell?
Anybody any idea?
Thanks
Carsten
2013/2/4 Victor Olaya <volayaf at gmail.com>
> it seems that many python plugins cause you problems. In this case it
> is the mmqgis plugin. I cannot help you much, but I would recommend
> uninstalling all you python plugins (remove everything under
> ""/home/user/.qgis//python/plugins" and then reinstall the ones you
> need one by one, and checking which ones have problems.
> Hope that helps
> Victor
> 2013/2/4 Carsten Hogertz <carsten.hogertz at gmail.com>:
> > Hi Victor,
> > thanks for your eMail. I deinstalled Sextante but I still got the
> following
> > Python-Error:
> > Fehler bei der Ausführung von Python-Code:
> > Traceback (most recent call last):
> >   File "/home/user/.qgis//python/plugins/mmqgis/mmqgis_dialogs.py", line
> > 959, in run
> >     message = mmqgis_geocode_google(self.iface, csvname, shapefilename,
> > notfoundfile, fields, 1)
> >   File "/home/user/.qgis//python/plugins/mmqgis/mmqgis_library.py", line
> > 1083, in mmqgis_geocode_google
> >     xml = urllib.urlopen(url).read()
> >   File "/usr/lib/python2.7/urllib.py", line 86, in urlopen
> >     return opener.open(url)
> >   File "/usr/lib/python2.7/urllib.py", line 207, in open
> >     return getattr(self, name)(url)
> >   File "/usr/lib/python2.7/urllib.py", line 344, in open_http
> >     h.endheaders(data)
> >   File "/usr/lib/python2.7/httplib.py", line 954, in endheaders
> >     self._send_output(message_body)
> >   File "/usr/lib/python2.7/httplib.py", line 814, in _send_output
> >     self.send(msg)
> >   File "/usr/lib/python2.7/httplib.py", line 776, in send
> >     self.connect()
> >   File "/usr/lib/python2.7/httplib.py", line 757, in connect
> >     self.timeout, self.source_address)
> >   File "/usr/lib/python2.7/socket.py", line 571, in create_connection
> >     raise err
> > IOError: [Errno socket error] [Errno 101] Das Netzwerk ist nicht
> erreichbar
> > Python-Version:
> > 2.7.3 (default, Aug  1 2012, 05:27:35)
> > [GCC 4.6.3]
> > QGIS-Version:
> > 1.8.0-Lisboa Lisboa, exported
> > Python-Pfad: ['/usr/share/qgis/python', '/home/user/.qgis//python',
> > '/home/user/.qgis//python/plugins', '/usr/share/qgis/python/plugins',
> > '/usr/local/lib/python2.7/dist-packages/OWSLib-0.5.1-py2.7.egg',
> > '/usr/local/lib/python2.7/dist-packages/libLAS-1.7.0-py2.7.egg',
> > '/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2',
> > '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
> > '/usr/lib/python2.7/lib-dynload',
> '/usr/local/lib/python2.7/dist-packages',
> '/usr/local/lib/python2.7/dist-packages/setuptools-0.6c11-py2.7.egg-info',
> > '/usr/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages/PIL',
> > '/usr/lib/python2.7/dist-packages/gst-0.10',
> > '/usr/lib/python2.7/dist-packages/gtk-2.0',
> '/usr/lib/pymodules/python2.7',
> > '/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
> > '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode',
> > '/home/user/.qgis/python/plugins/mmqgis/forms', '/usr/share/qgis/python',
> > '/usr/share/qgis/python/plugins/fTools/tools']
> > Any suggestions?
> > Thanks
> > Carsten
> >> Carsten
> >> That error is because you have installed the Permaclim plugin, but not
> >> the SEXTANTE plugin it depends on. Whether install SEXTANTE or
> >> uninstall the Permaclim plugin
> >> Regards
> >> Victor
> >> > Hi everyone,
> >> > evertime I start QGIS Desktop 1.8 I get the following Python error.
> This
> >> > error also appears with a lot of plugins too.
> >> > I'm on Ubuntu 11.10. Does anyone know how to solve this problem?
> >> > Thanks a lot.
> >> > Carsten
> >> > Konnte Erweiterung permaclim nicht laden wegen eines Fehler beim
> Aufruf
> >> > seiner classFactory()-Methode
> >> >   File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 164, in
> >> > startPlugin
> >> >     plugins[packageName] = package.classFactory(iface)
> >> >   File "/home/carsten/.qgis//python/plugins/permaclim/__init__.py",
> line
> >> > 45,
> >> > in classFactory
> >> >     from permaclim.SextantePermaclimProviderPlugin import
> >> >   File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 309, in
> >> > _import
> >> >     mod = _builtin_import(name, globals, locals, fromlist, level)
> >> >   File
> "/home/carsten/.qgis//python/plugins/permaclim/SextantePermaclimProviderPlugin.py",
> >> > line 32, in
> >> >     from sextante.core.Sextante import Sextante
> >> > _import
> >> > ImportError: No module named sextante.core.Sextante
> >> > Python-Version:
> >> > 2.7.2+ (default, Jul 20 2012, 22:24:03)
> >> > [GCC 4.6.1]
> >> > QGIS-Version:
> >> > Python-Pfad: ['/home/carsten/.qgis/python/plugins/GeoCoding',
> >> > '/usr/share/qgis/python', '/home/carsten/.qgis//python',
> >> > '/home/carsten/.qgis//python/plugins',
> >> > '/home/carsten/.qgis/python/plugins/mmqgis/forms']
> >> > _______________________________________________
> >> > Qgis-user mailing list
> >> > Qgis-user at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130204/a7f6a11f/attachment.html>
