[Qgis-user] QGIS Master, Sextante toolbox problem
    Salvatore Larosa
    lrssvtml at gmail.com
    Thu Feb  7 17:17:30 PST 2013
Hi Matteo,
2013/2/8 matteo <matteo.ghetta at gmail.com>
>  Hi,
> I updated the master version on my ubuntu 12.04 right now and I have the
> same problem:
> Couldn't load plugin sextante_taudem due an error when calling its
> classFactory() method
> Traceback (most recent call last):
>   File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 203, in
> startPlugin
>     plugins[packageName] = package.classFactory(iface)
>   File "/home/matteo/.qgis//python/plugins/sextante_taudem/__init__.py",
> line 55, in classFactory
>     from TauDEMProviderPlugin import TauDEMProviderPlugin
>   File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 452, in
> _import
>     mod = _builtin_import(name, globals, locals, fromlist, level)
>   File
> "/home/matteo/.qgis//python/plugins/sextante_taudem/TauDEMProviderPlugin.py",
> line 36, in
>     from sextante.core.Sextante import Sextante
> _import
>   File "/usr/share/qgis/python/plugins/sextante/__init__.py", line 20, in
>     from sextante.core.Sextante import runalg, runandload, alghelp,
> alglist, algoptions, load, loadFromAlg, extent, getObjectFromName,
> getObjectFromUri, features
> _import
>   File "/usr/share/qgis/python/plugins/sextante/core/Sextante.py", line
> 43, in
>     from sextante.algs.QGISAlgorithmProvider import QGISAlgorithmProvider
> _import
>   File
> "/usr/share/qgis/python/plugins/sextante/algs/QGISAlgorithmProvider.py",
> line 61, in
>     from sextante.algs.mmqgisx.MMQGISXAlgorithms import
> (mmqgisx_delete_columns_algorithm,
> _import
>   File
> "/usr/share/qgis/python/plugins/sextante/algs/mmqgisx/MMQGISXAlgorithms.py",
> line 29, in
>     from sextante.algs.mmqgisx.mmqgisx_library import *
> _import
> ImportError: No module named mmqgisx_library
> Python version:
> 2.7.3 (default, Aug  1 2012, 05:27:35)
> [GCC 4.6.3]
> QGIS version:
> 1.9.0-Master Master, exported
> Python path: ['/usr/share/qgis/python', '/home/matteo/.qgis//python',
> '/home/matteo/.qgis//python/plugins', '/usr/share/qgis/python/plugins',
> '/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2',
> '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
> '/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages/PIL',
> '/usr/lib/python2.7/dist-packages/gst-0.10',
> '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7',
> '/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
> '/usr/lib/python2.7/dist-packages/ubuntuone-client',
> '/usr/lib/python2.7/dist-packages/ubuntuone-control-panel',
> '/usr/lib/python2.7/dist-packages/ubuntuone-couch',
> '/usr/lib/python2.7/dist-packages/ubuntuone-installer',
> '/usr/lib/python2.7/dist-packages/ubuntuone-storage-protocol',
> '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode',
> '/home/matteo/.qgis/python/plugins/mmqgis/forms']
> Couldn't load plugin 'sextante' from ['/usr/share/qgis/python',
> '/home/matteo/.qgis//python', '/home/matteo/.qgis//python/plugins',
> '/usr/share/qgis/python/plugins', '/usr/lib/python2.7',
> '/usr/lib/python2.7/plat-linux2', '/usr/lib/python2.7/lib-tk',
> '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload',
>   File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 182, in
> loadPlugin
>     __import__(packageName)
> _import
> _import
> 43, in
> _import
>   File
> line 61, in
> _import
>   File
> line 29, in
> _import
> Python version:
> [GCC 4.6.3]
> QGIS version:
> Should I wait for the next nightly?
it looks like you have the plugin sextante_taudem in user plugins directory,
simply try to remove it from /home/matteo/.qgis/python/plugins
It is no longer necessary as the TauDem algs are in core. You can enable
the taudem algorithms from sextante options in Analysis menu.
Regards,
-SL
> Thanks
> Matteo
> Qgis-user mailing list
Salvatore Larosa
linkedIn: http://linkedin.com/in/larosasalvatore
twitter: @lrssvt
skype: s.larosa
IRC: lrssvt on freenode
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130208/2619af8b/attachment.html>
