[Qgis-user] Dashed lines with adjacent polygons
    HAUBOURG
    regis.haubourg at eau-adour-garonne.fr
    Thu Feb 14 06:08:42 PST 2013
Hi +1,
When using dashed lines too, overlaying dashed line results in continuous line on screen. Since keeping cumulative transparency of objects within the same layer is important to me, I don’t really see what we could do except using topology to display common boundaries only once. I have not tried this yet with postgis, and it is a bit heavy for such a small issue.
Any ideas?
régis
De : qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] De la part de Olivier Dalang
Envoyé : jeudi 14 février 2013 14:19
À : qgis-user at lists.osgeo.org
Objet : [Qgis-user] Dashed lines with adjacent polygons
Hi !
Is there a way to make dashed line between two polygons display well ? (typical use scenario : boundary between countries)
Since there are two superposed lines, the line sometimes appear dashed, sometimes solid, sometimes dashed but not with the right pattern...
Of course, one could use a line layer to draw this, but then it's more complex to maintain.
The same problem appears for transparent lines.
Any ideas ?
Thanks !!
Olivier
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130214/4a3dd2eb/attachment.html>
