[Qgis-user] Blinking white polygon over othophoto digitizing on linux
Gaspar Segués gaspar.segues at gmail.com
Sun Feb 17 12:20:50 PST 2013
Hi Giovanni,
I did not see your answer until today. It was an annoying flicker until few
minutes ago.
I will give an opportunity to the master version.
Thank you!
2012/9/1 Giovanni Manghi <giovanni.manghi at faunalia.pt>
> On Fri, 2012-08-31 at 13:04 +0200, Gaspar Segués wrote:
> > Hi!
> > When I digitize a line/polygon in linux/ubuntu a white rectangle
> > appears over the orthophoto, in the form of the figure, that blinks as
> > I move the cursor making dificult to continue. That don't happens when
> > I work with qgis on windows.
> > What's the reason? VGA driver?
> it is a known issue under Linux that has a workaround in qgis master
> options -> rendering -> enable back buffer
> cheers
> -- Giovanni --
*Gaspar Segués-Sais*
Tel. +34 656 323 669
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130217/a61b8f6d/attachment.html>
