[Qgis-user] Radiotelemetry triangulation data into QGIS
Borys Jurgiel
lists at borysjurgiel.pl
Fri Feb 22 05:26:47 PST 2013
It's very simple. You need any point layer with at least two numerical fields:
one with id of the fix, the second with bearing in degrees. For example:
x;y;bearing;fix_id
584846;4272513;0;1
584426;4272770;85;1
586034;4272041;265;2
584709;4271246;10;2
582800;4273011;112;2
The fix 1 has two points only, so it's simple. The fix 2 has three points, so a
triangle with centroid will be found.
Dnia czwartek, 21 lutego 2013 o 22:21:13 Milton Cezar Ribeiro napisaĆ(a):
> Hi Giovanni
> Where can I get information or a sample file to use as example to
> prepare my data?
> best whishes
> miltinho
> 2013/2/21, Giovanni Manghi <giovanni.manghi at faunalia.pt>:
> >> Message: 2
> >> Date: Thu, 21 Feb 2013 16:09:42 -0300
> >> From: Milton Cezar Ribeiro <miltinho.astronauta at gmail.com>
> >> To: qgis-user <qgis-user at lists.osgeo.org>
> >> Subject: [Qgis-user] Radiotelemetry triangulation data into QGIS
> >> Message-ID:
> >> <CADkzOEWxd=XCxNs0sF1zrJU5_rsrXfcMXufhW5vR3+O7n1xq1A at mail.gmail.com>
> >> Content-Type: text/plain; charset=ISO-8859-1
> >> Dear all
> >> I have a set of field surveyed data for a species, and the data are
> >> triangulation-based such as utm for each reading, and azimute (bean),
> >> and at least three reading for each species position on space and
> >> time.
> >> I knwow that if I have utmx and y I can use AniMove, also adehabitat
> >> family within R, but unfortunatelly it is not the case.
> >> Any idea of how can I convert my utm-xy and azimultes on species
> >> position?
> > use the "triangulation" plugin, it was made exactly for this purpose.
