[Qgis-user] Q GIs Repositories
José Pedro Santos
zpsantos1 at hotmail.com
Mon Feb 25 03:22:21 PST 2013
Salve fabio,
Seams that you have a problem with python or you don't have set the right permissions for /.qgis folder. Try to install phyton from the synaptic package manager or change the permissions.
I also found one reply that solve your problem in a mailing list:
"after (auto)update for all qgis libs in the synaptic manager, the error is solved"
Good luck.
Ciao
Jose Santos
Date: Mon, 25 Feb 2013 10:48:24 +0100
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Q GIs Repositories
I have installed Quantum GIS from The following Source Lists:
deb http://qgis.org/ubuntugis-nightly precise main
deb-src http://qgis.org/ubuntugis-nightly precise main
deb http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu precise main
And there is an error while open the program after installlation:
Couldn't load PyQGIS.
Python support will be disabled.
File "", line 1, in
ImportError: No module named qgis.core
Python version:
2.7.3 (default, Aug 1 2012, 05:27:35)
[GCC 4.6.3]
QGIS version:
1.9.0-Master 'Master', exported
Python path:
['/usr/share/qgis/python', '/home/fabio/.qgis//python', '/home/fabio/.qgis//python/plugins', '/usr/share/qgis/python/plugins', '/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2', '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages/PIL', '/usr/lib/python2.7/dist-packages/gst-0.10', '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7', '/usr/lib/python2.7/dist-packages/ubuntu-sso-client', '/usr/lib/python2.7/dist-packages/ubuntuone-client', '/usr/lib/python2.7/dist-packages/ubuntuone-control-panel', '/usr/lib/python2.7/dist-packages/ubuntuone-couch', '/usr/lib/python2.7/dist-packages/ubuntuone-installer', '/usr/lib/python2.7/dist-packages/ubuntuone-storage-protocol', '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode']
How can I fix It ?
TNX in advance
Fabio De Francesco
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130225/45ef57c2/attachment.html>
