[Qgis-user] jp2 error
Ramon AndiƱach
custard at westnet.com.au
Tue Feb 26 01:13:06 PST 2013
Hi Liam,
Unless I misunderstand (which is quite possible) the stand alone installer shouldn't have any problems with jp2s. At the very least the mrsid libraries sould be included and they should allow you to read jp2 files.
Sorry, but I'm probably not going to be much more help.
-ramon.
On 25/02/2013, at 08:34 , Liam Anderson wrote:
> Further info.
> This is a new install of 1.8 using the windows installer. I have reinstalled 1.7.4 and the jp2's work fine.
> Thanks
> On Mon, Feb 25, 2013 at 11:48 AM, Ramon AndiƱach <custard at westnet.com.au> wrote:
> Hi Liam,
> Couple of questions that will allow people to answer better.
> 1. Which way did you install QGIS on windows?
> (This is as important if not more so than what version of windows you're running)
> 2. Is this a new install? If not, have you been successful opening jp2 before?
> -ramon.
> On 25/02/2013, at 06:26 , Liam Anderson wrote:
> > Hi, I get an error when adding a jp2 raster to my project. I am running QGIS 1.8 on windows 7 64 bit. I was able to add the same jp2's on 1.7.
> > Error
> > C:\GIS\Imagery\Satelite\SPOTMaps\south_island.jp2 is not a supported raster data source
> > LTIImageReader::initialize(): failed to initialize reader from the stream "C:\GIS\Imagery\Satelite\SPOTMaps\south_island.jp2".
> > JP2: band sizes/shapes are irregular [50926]
> > I would love some advice.
> > Thanks
> > Liam
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
