[Qgis-user] "Grids for Atlas" plugin
Richard Duivenvoorde rdmailings at duif.net
Tue Feb 26 02:31:39 PST 2013
On 26-02-13 11:10, skampus wrote:
> i'm trying to use this plugin, but it returns an error (Ticket already open
> --> http://hub.qgis.org/issues/7232).
> is there anybody else having same problem?
this is a 'normal error' when you run master. Because of changes in the
api of current development version, plugin writers have to upgrade there
plugins.
You did the right thing to issue a ticket in the bug tracker (of the
plugin!). Now the plugin writer/manager will see it and hopefully update
your plugin.
But if you are able to also run the stable QGIS (version 1.8 at this
moment), the plugin should work fine in there.
Regards,
