[Qgis-user] Exporting SLD labels
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Thu Jan 3 08:25:43 PST 2013
Hi List,
I have a QML file which contains styling for a text layer. When I load the
QML file, it applies the appropriate stylings just fine.
I then "Save Style" as SLD. But it doesn't seem to save anything in it
apart from the fact there is no line symbol (correct). Is this expected?
Does QGIS not support exporting labels to SLD? If not, is there another
easy way to create SLD files with labels?
For reference, the QML (works fine):
<!DOCTYPE qgis PUBLIC 'http://mrcc.com/qgis.dtd' 'SYSTEM'>
<qgis version="1.8.0-Lisboa" minimumScale="0" maximumScale="1e+08"
hasScaleBasedVisibilityFlag="0">
<transparencyLevelInt>255</transparencyLevelInt>
<renderer-v2 symbollevels="0" type="singleSymbol">
<symbols>
<symbol outputUnit="MM" alpha="1" type="line" name="0">
<layer pass="0" class="SimpleLine" locked="0">
<prop k="capstyle" v="square"/>
<prop k="color" v="77,158,104,255"/>
<prop k="customdash" v="5;2"/>
<prop k="joinstyle" v="bevel"/>
<prop k="offset" v="0"/>
<prop k="penstyle" v="no"/>
<prop k="use_custom_dash" v="0"/>
<prop k="width" v="0.26"/>
</layer>
</symbol>
</symbols>
<rotation field=""/>
<sizescale field=""/>
</renderer-v2>
<customproperties>
<property key="labeling" value="pal"/>
<property key="labeling/addDirectionSymbol" value="false"/>
<property key="labeling/bufferColorB" value="255"/>
<property key="labeling/bufferColorG" value="255"/>
<property key="labeling/bufferColorR" value="255"/>
<property key="labeling/bufferSize" value="0"/>
<property key="labeling/dataDefinedProperty0" value=""/>
<property key="labeling/dataDefinedProperty1" value=""/>
<property key="labeling/dataDefinedProperty10" value=""/>
<property key="labeling/dataDefinedProperty11" value=""/>
<property key="labeling/dataDefinedProperty12" value=""/>
<property key="labeling/dataDefinedProperty13" value=""/>
<property key="labeling/dataDefinedProperty14" value=""/>
<property key="labeling/dataDefinedProperty2" value=""/>
<property key="labeling/dataDefinedProperty3" value=""/>
<property key="labeling/dataDefinedProperty4" value=""/>
<property key="labeling/dataDefinedProperty5" value=""/>
<property key="labeling/dataDefinedProperty6" value=""/>
<property key="labeling/dataDefinedProperty7" value=""/>
<property key="labeling/dataDefinedProperty8" value=""/>
<property key="labeling/dataDefinedProperty9" value=""/>
<property key="labeling/decimals" value="0"/>
<property key="labeling/dist" value="0"/>
<property key="labeling/distInMapUnits" value="false"/>
<property key="labeling/enabled" value="true"/>
<property key="labeling/fieldName" value="TEXTSTRING"/>
<property key="labeling/fontFamily" value="Calibri"/>
<property key="labeling/fontItalic" value="false"/>
<property key="labeling/fontSize" value="10"/>
<property key="labeling/fontSizeInMapUnits" value="false"/>
<property key="labeling/fontStrikeout" value="false"/>
<property key="labeling/fontUnderline" value="false"/>
<property key="labeling/fontWeight" value="50"/>
<property key="labeling/formatNumbers" value="false"/>
<property key="labeling/isExpression" value="false"/>
<property key="labeling/labelPerPart" value="false"/>
<property key="labeling/mergeLines" value="false"/>
<property key="labeling/minFeatureSize" value="0"/>
<property key="labeling/obstacle" value="true"/>
<property key="labeling/placement" value="2"/>
<property key="labeling/placementFlags" value="9"/>
<property key="labeling/plussign" value="true"/>
<property key="labeling/priority" value="5"/>
<property key="labeling/scaleMax" value="2500"/>
<property key="labeling/scaleMin" value="1"/>
<property key="labeling/textColorB" value="0"/>
<property key="labeling/textColorG" value="0"/>
<property key="labeling/textColorR" value="0"/>
<property key="labeling/wrapChar" value=""/>
</customproperties>
<displayfield>OS_ID</displayfield>
<label>0</label>
<labelattributes>
<label fieldname="" text="Label"/>
<family fieldname="" name="MS Shell Dlg 2"/>
<size fieldname="" units="pt" value="12"/>
<bold fieldname="" on="0"/>
<italic fieldname="" on="0"/>
<underline fieldname="" on="0"/>
<strikeout fieldname="" on="0"/>
<color fieldname="" red="0" blue="0" green="0"/>
<x fieldname=""/>
<y fieldname=""/>
<offset x="0" y="0" units="pt" yfieldname="" xfieldname=""/>
<angle fieldname="" value="0" auto="0"/>
<alignment fieldname="" value="center"/>
<buffercolor fieldname="" red="255" blue="255" green="255"/>
<buffersize fieldname="" units="pt" value="1"/>
<bufferenabled fieldname="" on=""/>
<multilineenabled fieldname="" on=""/>
<selectedonly on=""/>
</labelattributes>
<edittypes>
<edittype type="0" name="ANCHOR_POSITION"/>
<edittype type="0" name="CHANGE_HISTORY"/>
<edittype type="0" name="DESCRIPTIVE_GROUP"/>
<edittype type="0" name="DESCRIPTIVE_TERM"/>
<edittype type="0" name="FEATURE_CODE"/>
<edittype type="0" name="FONT"/>
<edittype type="0" name="HEIGHT"/>
<edittype type="0" name="LAST_CHANGE_DATE"/>
<edittype type="0" name="MAKE"/>
<edittype type="0" name="MI_PRINX"/>
<edittype type="0" name="MI_STYLE"/>
<edittype type="0" name="ORIENTATION"/>
<edittype type="0" name="OSMMSTYLE_NAME"/>
<edittype type="0" name="OS_ID"/>
<edittype type="0" name="SURFACE_LEVEL"/>
<edittype type="0" name="TEXTSTRING"/>
<edittype type="0" name="THEME"/>
<edittype type="0" name="VERSION"/>
<edittype type="0" name="VERSION_DATE"/>
</edittypes>
<editform></editform>
<editforminit></editforminit>
<annotationform></annotationform>
<attributeactions/>
</qgis>
And the SLD (doesn't work fine):
<StyledLayerDescriptor xmlns="http://www.opengis.net/sld" xmlns:ogc="
http://www.opengis.net/ogc" xmlns:xsi="
http://www.w3.org/2001/XMLSchema-instance" version="1.1.0" xmlns:xlink="
http://www.w3.org/1999/xlink" xsi:schemaLocation="http://www.opengis.net/sld
http://schemas.opengis.net/sld/1.1.0/StyledLayerDescriptor.xsd" xmlns:se="
http://www.opengis.net/se">
<NamedLayer>
<se:Name>carto_text</se:Name>
<UserStyle>
<se:FeatureTypeStyle>
<se:Rule>
<se:Name>Single symbol</se:Name>
</se:Rule>
</se:FeatureTypeStyle>
</UserStyle>
</NamedLayer>
</StyledLayerDescriptor>
Thanks,
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130103/461425a4/attachment.html>
