[Qgis-user] RES: Help with Sextante Modeler
Juliano Augusto Candido Silva
JulianoCandido at thisisnoble.com
Thu Jan 3 08:31:21 PST 2013
See it.
The SEXTANTE version is 1.0.8
Tnx for the help
Juliano Cândido
-----Mensagem original-----
De: Victor Olaya [mailto:volayaf at gmail.com]
Enviada em: quinta-feira, 3 de janeiro de 2013 14:26
Para: Juliano Augusto Candido Silva
Cc: qgis-user at lists.osgeo.org
Assunto: Re: [Qgis-user] Help with Sextante Modeler
Juliano
Can you share the file with model that is causing the error?
Are you using a stable version of SEXTANTE, or the latest GitHub version?
Thanks for your help!
Victor
2013/1/3 Juliano Augusto Candido Silva <JulianoCandido at thisisnoble.com>:
> Hi Guys!
> Can u help me with the Sextante Modeler?
> I got an error everytime that I try to run a model with more than 3
> operations.
> The operations are:
> 1) Input Table (from modeler)
> 2) Convert Table to Points (from SAGA)
> 3) Rasterize (v.to.rast.attribute - From GRASS)
> Nothing is created and I got this error as retrieve:
> "Traceback (most recent call last):
> File "C:/./core;geoalgorithm.py", line 118, in execute
> self..processAlgorithm(progress)
> File "C:/./ModelerAlgorithm.py" Line 435, in processAlgorithm
> Progress.setdebugInfo("Model processed ok. Executed %i algorithms
> total"%
> iAlg)
> UnboundLocalError: local variable 'iAlg' referenced before Assignment"
> Any help? Any suggestions about modeling in QGIS?
> Hugs
> Juliano Augusto Cândido Silva - Research Team
> Noble Group
> www.thisisnoble.com
> Qgis-user mailing list
Type: application/octet-stream
Desc: RAINMODEL.model
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130103/e19989b9/attachment.obj>
