[Qgis-user] Exporting SLD labels
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Fri Jan 4 03:10:26 PST 2013
Thanks Giuseppe,
My second question was more generic than needing to be from QML.
Basically, is there a way of exporting an SLD with labelling information
from QGIS? Or indeed any application? Or am I going to have to hand-code
them?
Thanks,
Jonathan
On 3 January 2013 20:53, Giuseppe Sucameli <brush.tyler at gmail.com> wrote:
> Hi Jonathan,
> On Thu, Jan 3, 2013 at 5:25 PM, Jonathan Moules
> <jonathanmoules at warwickshire.gov.uk> wrote:
> > Does QGIS not support exporting labels to SLD?
> it's not supported yet.
> > If not, is there another easy way to
> > create SLD files with labels?
> No other ways to convert a QML to SLD, as far as I know.
> Regards.
> > For reference, the QML (works fine):
> > <!DOCTYPE qgis PUBLIC 'http://mrcc.com/qgis.dtd' 'SYSTEM'>
> > <qgis version="1.8.0-Lisboa" minimumScale="0" maximumScale="1e+08"
> > hasScaleBasedVisibilityFlag="0">
> > <transparencyLevelInt>255</transparencyLevelInt>
> > <renderer-v2 symbollevels="0" type="singleSymbol">
> > <symbols>
> > <symbol outputUnit="MM" alpha="1" type="line" name="0">
> > <layer pass="0" class="SimpleLine" locked="0">
> > <prop k ="capstyle" v="square"/>
> > <prop k="color" v="77,158,104,255"/>
> > <prop k="customdash" v="5;2"/>
> > <prop k="joinstyle" v="bevel"/>
> > <prop k="offset" v="0"/>
> > <prop k="penstyle" v="no"/>
> > <prop k="use_custom_dash" v="0"/>
> > <prop k="width" v="0.26"/>
> > </layer>
> > </symbol>
> > </symbols>
> > <rotation field=""/>
> > <sizescale field=""/>
> > </renderer-v2>
> > <customproperties>
> > <property key="labeling" value="pal"/>
> > <property key="labeling/addDirectionSymbol" value="false"/>
> > <property key="labeling/bufferColorB" value="255"/>
> > <property key="labeling/bufferColorG" value="255"/>
> > <property key ="labeling/bufferColorR" value="255"/>
> > <property key="labeling/bufferSize" value="0"/>
> > <property key="labeling/dataDefinedProperty0" value=""/>
> > <property key="labeling/dataDefinedProperty1" value=""/>
> > <property key="labeling/dataDefinedProperty10" value=""/>
> > <property key="labeling/dataDefinedProperty11" value=""/>
> > <property key="labeling/dataDefinedProperty12" value=""/>
> > <property key="labeling/dataDefinedProperty13" value=""/>
> > <property key="labeling/dataDefinedProperty14" value=""/>
> > <property key="labeling/dataDefinedProperty2" value=""/>
> > <property key="labeling/dataDefinedProperty3" value=""/>
> > <property key="labeling/dataDefinedProperty4" value=""/>
> > <property key="labeling/dataDefinedProperty5" value=""/>
> > <property key="labeling/dataDefinedProperty6" value=""/>
> > <property key="labeling/dataDefinedProperty7" value=""/>
> > <property key="labeling/dataDefinedProperty8" value=""/>
> > <property key="labeling/dataDefinedProperty9" value=""/>
> > <property key="labeling/decimals" value="0"/>
> > <property key="labeling/dist" value="0"/>
> > <property key="labeling/distInMapUnits" value="false"/>
> > <property key="labeling/enabled" value="true"/>
> > <property key="labeling/fieldName" value="TEXTSTRING"/>
> > <property key="labeling/fontFamily" value="Calibri"/>
> > <property key="labeling/fontItalic" value="false"/>
> > <property key="labeling/fontSize" value="10"/>
> > <property key="labeling/fontSizeInMapUnits" value="false"/>
> > <property key="labeling/fontStrikeout" value="false"/>
> > <property key="labeling/fontUnderline" value="false"/>
> > <property key="labeling/fontWeight" value="50"/>
> > <property key="labeling/formatNumbers" value="false"/>
> > <property key="labeling/isExpression" value="false"/>
> > <property key="labeling/labelPerPart" value="false"/>
> > <property key="labeling/mergeLines" value="false"/>
> > <property key="labeling/minFeatureSize" value="0"/>
> > <property key="labeling/obstacle" value="true"/>
> > <property key="labeling/placement" value="2"/>
> > <property key="labeling/placementFlags" value="9"/>
> > <property key="labeling/plussign" value="true"/>
> > <property key="labeling/priority" value="5"/>
> > <property key="labeling/scaleMax" value="2500"/>
> > <property key="labeling/scaleMin" value="1"/>
> > <property key="labeling/textColorB" value="0"/>
> > <property key="labeling/textColorG" value="0"/>
> > <property key="labeling/textColorR" value="0"/>
> > <property key="labeling/wrapChar" value=""/>
> > </customproperties>
> > <displayfield>OS_ID</displayfield>
> > <label>0</label>
> > <labelattributes>
> > <label fieldname="" text="Label"/>
> > <family fieldname="" name="MS Shell Dlg 2"/>
> > <size fieldname="" units="pt" value ="12"/>
> > <bold fieldname="" on="0"/>
> > <italic fieldname="" on="0"/>
> > <underline fieldname="" on="0"/>
> > <strikeout fieldname="" on="0"/>
> > <color fieldname="" red="0" blue="0" green="0"/>
> > <x fieldname=""/>
> > <y fieldname=""/>
> > <offset x="0" y="0" units="pt" yfieldname="" xfieldname=""/>
> > <angle fieldname="" value="0" auto ="0"/>
> > <alignment fieldname="" value="center"/>
> > <buffercolor fieldname="" red="255" blue="255" green="255"/>
> > <buffersize fieldname="" units="pt" value="1"/>
> > <bufferenabled fieldname="" on=""/>
> > <multilineenabled fieldname="" on=""/>
> > <selectedonly on=""/>
> > </labelattributes>
> > <edittypes>
> > <edittype type="0" name="ANCHOR_POSITION"/>
> > <edittype type="0" name="CHANGE_HISTORY"/>
> > <edittype type="0" name="DESCRIPTIVE_GROUP"/>
> > <edittype type="0" name="DESCRIPTIVE_TERM"/>
> > <edittype type="0" name="FEATURE_CODE"/>
> > <edittype type="0" name="FONT"/>
> > <edittype type="0" name="HEIGHT"/>
> > <edittype type="0" name="LAST_CHANGE_DATE"/>
> > <edittype type="0" name="MAKE"/>
> > <edittype type="0" name="MI_PRINX"/>
> > <edittype type="0" name="MI_STYLE"/>
> > <edittype type="0" name="ORIENTATION"/>
> > <edittype type="0" name="OSMMSTYLE_NAME"/>
> > <edittype type="0" name="OS_ID"/>
> > <edittype type="0" name="SURFACE_LEVEL"/>
> > <edittype type="0" name="TEXTSTRING"/>
> > <edittype type="0" name="THEME"/>
> > <edittype type="0" name="VERSION"/>
> > <edittype type="0" name="VERSION_DATE"/>
> > </edittypes>
> > <editform></editform>
> > <editforminit></editforminit>
> > <annotationform></annotationform>
> > <attributeactions/>
> > </qgis>
> > And the SLD (doesn't work fine):
> > <?xml version="1.0" encoding="UTF-8"?>
> > <StyledLayerDescriptor xmlns="http://www.opengis.net/sld"
> > xmlns:ogc="http://www.opengis.net/ogc"
> > xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.1.0"
> > xmlns:xlink="http://www.w3.org/1999/xlink"
> > xsi:schemaLocation="http://www.opengis.net/sld
> > http://schemas.opengis.net/sld/1.1.0/StyledLayerDescriptor.xsd"
> > xmlns:se="http://www.opengis.net/se">
> > <NamedLayer>
> > <se:Name>carto_text</se:Name>
> > <UserStyle>
> > <se:FeatureTypeStyle>
> > <se:Rule>
> > <se:Name>Single symbol</se:Name>
> > </se:Rule>
> > </se:FeatureTypeStyle>
> > </UserStyle>
> > </NamedLayer>
> > </StyledLayerDescriptor>
> > Thanks,
> > Jonathan
> > This transmission is intended for the named addressee(s) only and may
> > contain sensitive or protectively marked material up to RESTRICTED and
> > should be handled accordingly. Unless you are the named addressee (or
> > authorised to receive it for the addressee) you may not copy or use it,
> or
> > disclose it to anyone else. If you have received this transmission in
> error
> > please notify the sender immediately. All email traffic sent to or from
> us,
> > including without limitation all GCSX traffic, may be subject to
> recording
> > and/or monitoring in accordance with relevant legislation.
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> Giuseppe Sucameli
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130104/0e4021c0/attachment.html>
