[Qgis-user] Problem downloading exercise data
    Johan Nilsson
    joni8135 at gmail.com
    Sat Jan  5 02:21:49 PST 2013
To the list-administrators
Normally If you edit the subject line, the answer not following the thread.
Another problem with this list is that when you reply to the list, the
default is to the sender, not the mail-list. The other alternative is reply
everybody, and that are not so good either.
I use Google web-mail, so it is not a mail-client issue.
Cheers
2013/1/5 Oluwole Morenikeji <wolekeji at yahoo.com>
> What I found at the referenced data site could not be downloaded to work
> with in the training manual
> https://github.com/qgis/QGIS-Training-Manual/tree/master/exercise_data
> *From:* "qgis-user-request at lists.osgeo.org" <
> qgis-user-request at lists.osgeo.org>
> *To:* qgis-user at lists.osgeo.org
> *Sent:* Friday, January 4, 2013 9:00 PM
> *Subject:* Qgis-user Digest, Vol 83, Issue 8
> Send Qgis-user mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
>     http://lists.osgeo.org/mailman/listinfo/qgis-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>     qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
>   1. Re: Could not find exercise data (Andre Joost)
>   2. Re: Newbie with request for advice (Art)
> Message: 1
> Date: Fri, 04 Jan 2013 16:30:48 +0100
> From: Andre Joost <andre+joost at nurfuerspam.de>
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Could not find exercise data
> Message-ID: <kc6sjg$e2l$1 at ger.gmane.org>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> Am 04.01.2013 15:09, schrieb Oluwole Morenikeji:
> > I installed
> > Qgis 1.8 and its latest training manual release. I also downloaded qgis
> sample
> > data but following the training manual the data used for the training is
> not
> > found in the sample data folder e.g.  I was frustrated following this
> > instruction
> > Click on the Browse button and navigate to the file
> > exercise_data/streets.shp
> > (in your course directory). What I found in the directory is Alaska
> folder.
> > What do I do please.
> I guess you are looking for this data:
> I wish someone could put a link on the page where the training manual is...
> HTH,
> Andr? Joost
> Message: 2
> Date: Fri, 04 Jan 2013 13:49:10 -0600
> From: Art <alf1361 at zoho.com>
> To: qgis-user <qgis-user at lists.osgeo.org>
> Subject: Re: [Qgis-user] Newbie with request for advice
> Message-ID: <50E73236.7070400 at zoho.com>
> Content-Type: text/plain; charset="iso-8859-1"; Format="flowed"
> Yes! Any information on implementing this feature on Linux would be much
> appreciated.
> Art
> On 1/4/2013 8:08 AM, Johan Nilsson wrote:
> > I'm also very interested in 'ESRI file geodatabase', not the 'Personal
> > geodatabase', ( mdb or ms-access, or JET database) that ESRI not
> > recommend to use...
> > I tried to compile for month ago, but I think I stuck on the same
> > place Art get stuck..
> > /Cheers
> > 2013/1/4 Randal Hale <rjhale at northrivergeographic.com
> > <mailto:rjhale at northrivergeographic.com>>
> >    Hi Art,
> >    So I've got QGIS running on windows and linux. I haven't tried to
> >    compile file geodatabase support into my linux install (that's on
> >    my list to do). On my windows install I'm running OSGeo4Win -
> >    adding file based geodatabase support was easy - I just added the
> >    "module" and had support (I'm currently on my linux machine and
> >    not near my windows machine - or I would tell you exactly what I
> >    added).
> >    My windows machine is running Windows 7 64bit - my linux machine
> >    is running xubuntu. I own a consulting business and have ArcGIS
> >    running on my windows machine. There's not way I'm ever going to
> >    windows 8. So I'm sticking with windows 7 for ESRI and migrating
> >    as much of my workflow over to linux as I can...as I tell people -
> >    A clip is a clip and a buffer is a buffer. So I'll do what I can
> >    on linux and when I have to go with ESRI I'll jump over to windows.
> >    Now that I read all of this - I should really try to compile file
> >    based support on this laptop over the weekend.
> >    Randy
> >    Randal Hale, GISP
> >    North River Geographic Systems, Inc
> >    http://www.northrivergeographic.com
> >    423.653.3611  <tel:423.653.3611>  rjhale at northrivergeographic.com
> >    twitter:rjhale
> >    http://about.me/rjhale
> >    On 01/01/2013 03:05 PM, Art wrote:
> >>    I have two options right now. I am a Linux lover, and I am
> >>    investigating compiling the Esri File Geodatabase API on Linux.
> >>    However, the other option is to handle it all through Windows,
> >>    probably using OsGeo4Win. That means I would probably have to
> >>    make a switch to Windows. I do have a copy of ESRI's ArcGIS that
> >>    will work until August that was given to me for a GIS Course, so
> >>    I will have that option for some time but it will not be
> >>    permanent. Does anyone have a recommended course of action? I
> >>    have attached the results from my last compile attempt involving
> >>    the File Geodatabase API. I have not found a detailed set of
> >>    compiling instructions to make and install it, and am uncertain
> >>    as to how I should proceed further.
> >>    Art
> >>    _______________________________________________
> >>    Qgis-user at lists.osgeo.org  <mailto:Qgis-user at lists.osgeo.org>
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20130104/f4228057/attachment-0001.html
> End of Qgis-user Digest, Vol 83, Issue 8
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130105/b5e47c31/attachment.html>
