[Qgis-user] Qgis doesn't load the resulting vector on Mac
gvSIGMac
gvsig.mac at gmail.com
Tue Jan 8 04:44:16 PST 2013
Maybe is only question of an extra shp in the name, see below, but when I obtain a new vector with sextante, qgis either claims that the file can't be found or when the layer is loaded to the TOC, there is no visible result.
In both instances if I Load the result again things work as expected.
To be clear the result is produced.
The only difference I can appreciate is that in the automatically loaded file the name contains .shp at the end.
result # data are shown
result.shp # empty file
No error reported to log.
Qgis Master 314d144
Agustin
On 07/01/2013, at 13:22, Victor Olaya <volayaf at gmail.com> wrote:
> But that will create a huge number of versions in the plugin page. I
> thought that it was meant to be used for stable versions, not for
> daily ones, right?
> Victor
> 2013/1/7 Paolo Cavallini <cavallini at faunalia.it>:
>> Il 05/01/2013 16:31, Victor Olaya ha scritto:
>>> I am thinking about creating daily versions of the SEXTANTE code, so
>> can't you just publish it through plugins.qgis.org?
>> a simple script to zip and upload it should do the trick.
>> all the best.
>> Paolo Cavallini - Faunalia
>> www.faunalia.eu
>> Full contact details at www.faunalia.eu/pc
>> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
