[Qgis-user] project makes qgis crash upon startup
Agustin Lobo
alobolistas at gmail.com
Tue Jan 8 05:40:57 PST 2013
Andre,
On Tue, Jan 8, 2013 at 10:10 AM, Andre Joost <andre+joost at nurfuerspam.de> wrote:
> The .qgis file is a simple xml text file, which you can edit with everey
> text editor. I use notepad++ on Windows for such things.
But that structure is too complicated as soon as the project is minimally large.
I refer to an editor that would be able to interpret the structure so
that we could
have a tree that could be expanded and collapsed, delete layers etc.A bit
as if you had the legend (or TOC), but not actually reading or
displaying the layers.
Maybe there is an option that would make qgis to act that way.
> If you use relative paths, make sure not to move your datasources or qgis
> files within the file system. Interchanging between Linux and Mac may most
> probably not work though.
Never have had such problems with relative paths and have used linux,
mac and Win
qgis versions very often with the data on an external hard disk. Even
if my disk is /media/Iomega in linux and /Volume/Iomega. in Mac
The realtive path has always worked very well for me.
Thanks!
Agus
> HTH,
> André Joost
> Am 08.01.13 07:50, schrieb Agustin Lobo:
>> Hi!
>> A project that used to work fine few days ago cannot be opened
>> any more with qgis 1.8: the program crashes before even starting to
>> write the TOC . I've tried with qgis --noplugin and get the same problem,
>> so this is not an issue of plugin conflicts. The problem occurs
>> on linux and mac.
>> Is there any way I can debug the project file? Perhaps an xml editor
>> for project files would let me select parts of the file more easily than
>> just
>> a text editor?
> Qgis-user mailing list
