[Qgis-user] Region of Select Tool remains (qgis 1.8 Win)
Agustin Lobo
alobolistas at gmail.com
Wed Jan 9 07:02:08 PST 2013
It seems a bit different, as I do not have any group.
I've found the problem when using the Select Tool while having a
raster layer selected instead of
having a vector layer (by mistake, of course). Hopefully the same
solution fixes both
problems, but it would be worth checking (I do not have master).
Agus
On Wed, Jan 9, 2013 at 2:34 PM, Salvatore Larosa <lrssvtml at gmail.com> wrote:
> Hi,
> 2013/1/9 Agustin Lobo <alobolistas at gmail.com>
>> Sometimes the semi-transparent rectangle drawn by the Select Tool does
>> not vanish:
>> http://dl.dropbox.com/u/3180464/select.jpeg
>> even after refreshing or subsequent selections.
>> Had not seen this problem on linux or Mac.
>> Any solution other than exiting and starting up again?
> known issue [1] and already fixed in master branch !
> Regards,
> -SL
> [1] .- hub.qgis.org/issues/6937
>> Thanks
>> Agus
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Salvatore Larosa
> linkedIn: http://linkedin.com/in/larosasalvatore
> twitter: @lrssvt
> skype: s.larosa
> IRC: lrssvt on freenode
