[Qgis-user] Sextante Saga Add Grid Values to points
Victor Olaya
volayaf at gmail.com
Fri Jan 11 06:14:36 PST 2013
Michal
Those are actually not errors, but the log of your activity. Is saga
not producing the layer you want? It seems there is no problem, since
the output contains no error messages
Regards
2013/1/11 Michał Bełcik <belcikmichal at gmail.com>:
> Hello everyone!
> While executing Saga Add Grid Values to Points module, such error appears:
> sextante.runalg("saga:shapestogrid","C:/Users/Work/Desktop/Dokumenty/Working
> files/Sobibor Forest District/DaneNumeryczna_Sobibor/NUMERYCZNA/Warstwy
> pochodne
> sobibor/ciek_lin.shp","ID_OB",0,0,1,0,"797460.17,825454.42,389177.88,417040.13",10,None)
> and:
> SAGA execution console output
> C:\>set SAGA=C:\Saga
> C:\>set SAGA_MLB=C:\Saga\modules
> C:\>PATH=PATH;C:\Saga;C:\Saga\modules
> C:\>saga_cmd grid_gridding "Shapes to Grid" -INPUT
> "C:/Users/Work/Desktop/Dokumenty/Working files/Sobibor Forest
> District/DaneNumeryczna_Sobibor/NUMERYCZNA/Warstwy pochodne
> sobibor/ciek_lin.shp" -FIELD "ID_OB" -MULTIPLE 0 -LINE_TYPE 0 -GRID_TYPE 1
> -TARGET 0 -USER_XMIN 797465.17 -USER_XMAX 825449.42 -USER_YMIN 389182.88
> -USER_YMAX 417035.13 -USER_SIZE 10 -USER_GRID
> "C:\Users\Work\AppData\Local\Temp\sextante\sagashapestogridc90962458b2b450e8213cf5de998bc57.tif.sgrd"
> C:\>saga_cmd io_gdal 1 -GRIDS
> -FORMAT 1 -TYPE 0 -FILE
> "C:\Users\Work\AppData\Local\Temp\sextante\sagashapestogridc90962458b2b450e8213cf5de998bc57.tif"
> C:\>exit
> Is it a bug, or there is some problem on my computer?
> Best regards
> Michal
> Qgis-user mailing list
