[Qgis-user] GPS Tools plugin
Gerardo Jimenez
gejst5 at hotmail.com
Tue Jan 15 06:01:56 PST 2013
Hi
According to the GPS Babel documentation your unit (I have the same problem with an etrex 10 unit):
" uses GPX format, not Garmin protocol. Therefore one should
communicate with it by reading and writing GPX files instead of using
this format. Members of this class of products do not support realtime
positioning protocol"
I think this cause that you can not download your data directly in qgis. Try to use EasyGps (a free tool). You can download the data, save as gpx and integrate it in Qgis with GPS tools.
Hope it helps
Gerardo Jiménez Delgado
Instituto de Investigaciones Antropológicas
Universidad Nacional Autónoma de México
Ciudad Universitaria s/n
Coyoacan 04510
Mexico City
Mexico
56 22 95 16
Date: Tue, 15 Jan 2013 18:18:03 +0530
To: Qgis-user at lists.osgeo.org
Subject: [Qgis-user] GPS Tools plugin
I am not able to 'Download from GPS' & 'Upload to GPS' using model 'Garmin Map78S' in .
OS is Windows-7 32 bit.
GPSBabel-1.4.4-Setup.exe is installed. Port used is usb:.
After reading official tutorial's 'Defining new device types' section, Waypoint download command line is changed as:
gpsbabel -w -i garmin -o gpx usb: F:\test\hks.gpx
Message appears is 'The layer F:/test/hks.gpx?type=waypoint is not a valid layer and can not be added to the map'
What to do further? Is there any previous discussion for this?
Regards
Harish Kumar Solanki
Qgis-user mailing list
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130115/b16f0c33/attachment.html>
