[Qgis-user] Is there a way to calculate a devision in Sextante Field Calculator for QGIS 1.8?
Victor Olaya
volayaf at gmail.com
Thu Jan 17 00:27:52 PST 2013
I have just tried with both versions and the division works without problem...
It is weird that you can substract the values but not divide them.
You can try to express aFIELD / bFIELD as aFIELD * (bFIELD**-1) Maybe
that works
Hope this helps. I will have a detailed look at the calculator to see
if I can reproduce that error. It happens only in the modeler or
everywhere?
Regards
Victor
2013/1/17 Anita Graser <anitagraser at gmx.at>:
> Hi,
> I'm running QGIS 1.8 with Sextante 1.0.8. In one of my models, I want
> to calculate a devision: aFIELD / bFIELD but there is always the same
> error: Problem evalutaion formula: Wrong field values or formula.
> (Note: aFIELD - bFIELD does work!) Is there a workaround for the
> release version? (I assume it works in the current dev version.)
> Thanks
> Anita
> Qgis-user mailing list
