[Qgis-user] Square symbol with no fill
    Andreas Neumann
    a.neumann at carto.net
    Fri Jan 18 13:01:36 PST 2013
I know - it is an annoyance that should/will be fixed in version 2.0
Meanwhile you could do either of the two workarounds:
* use the Ellipse renderer as a workaround and select the rectangle
* use your own SVG symbol (which you can write either by hand (very
simple) or in Inkscape or Illustrator.
The ellipse renderer is probably easier, since you want to scale it
based on a database value.
Andreas
On 1/18/13 8:00 PM, Des Callaghan wrote:
> Hello Forum,
> With the new symbology, I wish to use a point symbol that is a square
> without any fill (i.e. an open square) and which I can vary the size
> using a size scale field. Try as I might, I've only found squares that
> have a fill. Is a 'no fill' square symbol option available? Thanks for
> any help.
> Best regards,
> Des
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130118/0b299925/attachment.html>
