[Qgis-user] QGIS for surfaces documentation (of Mural Painting)
Nick Hopton nhopton at gmail.com
Sun Jan 27 03:59:14 PST 2013
If you know the dimensions of the painting then georeferencing the image
should not present problems. For example, if the painting is 200 cm wide by
100 cm high you could georeference the image using a coordinate of 0,0 for
its bottom left-hand corner and 200,100 for its top right-hand corner. In
the georeferencer use 'Helmert' and 'Linear' and set a CRS of (say)
EPSG:3395. The CRS is not really important in your case, but you have to
specify something. N.
View this message in context: http://osgeo-org.1560.n6.nabble.com/QGIS-for-surfaces-documentation-of-Mural-Painting-tp5030059p5030096.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
