[Qgis-user] Layer encoding
Andre Joost
andre+joost at nurfuerspam.de
Tue Jan 29 12:11:40 PST 2013
do you work with QGIS 1.8.0 Lisboa?
There was a bug in shapefile encoding, which is fixed in current master.
You might try that, or wait for QGIS 2.0.
Greetings,
André Joost
Am 29.01.2013 20:28, schrieb Matej Mailing:
> Hi,
> When changing setting Encoding at layer properties / General tab from UTF-8
> to any other, for example System, it seems that even after clicking OK
> encoding setting doesn't seem to save - when I check this value again, it
> is still UTF-8.
> What am I doing wrong? The data in the table is not in the UTF-8 and I want
> to change this value.
> Thanks,
> Matej
> Qgis-user mailing list
