[Qgis-user] EPSG:27700 - OSGB 1936 / British National Grid shapefiles are incorrectly interpreted by QGIS 1.8.0 and later
Andrew Chapman
andrew.chapman at donkagen.co.uk
Thu Jan 31 05:25:58 PST 2013
Pardon my ignorance here - I'm not (nor do I wish to become) a GIS expert
with detailed knowledge of all the ins and outs of CRSs. While I can
understand that to some users it could be critical to know with ultimate
accuracy the location of any specified point as a world coordinate, what
ultimately matters to me is to be able to agree with other users that we
consistently interpret our mapping data in the same way - point A is always
in the same place on each of our systems, subject obviously to specifying
the CRS.
Using shapefiles, as I understand it, the .prj file specifies how everything
should line up. For OSGB 1936 this has historically been
PROJCS["OSGB_1936_British_National_Grid",GEOGCS["GCS_OSGB
1936",DATUM["D_OSGB_1936",SPHEROID["Airy_1830",6377563.396,299.3249646]],PRI
MEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transver
se_Mercator"],PARAMETER["latitude_of_origin",49],PARAMETER["central_meridian
",-2],PARAMETER["scale_factor",0.9996012717],PARAMETER["false_easting",40000
0],PARAMETER["false_northing",-100000],UNIT["Meter",1]]
If I get layers from Ordnance Survey, my county council GIS department or
other town and parish councils, I would expect my example point A to stay in
the same place whatever GIS software I use.
I'm not sure what is being suggested here as a fix. Is it going back to the
pre 1.8.0 solution or providing an alternative CRS that the user will need
to select for all affected layers in every project? If the latter it will
potentially cause problems for those of us sharing projects between machines
using different version of QGIS.
Sorry - I'm just having trouble getting my head around this!
Andrew Chapman
-----Original Message-----
From: Even Rouault [mailto:even.rouault at mines-paris.org]
Sent: 31 January 2013 12:24
To: Andrew Chapman
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] EPSG:27700 - OSGB 1936 / British National Grid
Selon Andrew Chapman <andrew.chapman at donkagen.co.uk>:
There's a GDAL ticket about that : http://trac.osgeo.org/gdal/ticket/4597
Frank, I've attached in it a libgeotiff patch that should solve this by
defining an override.
