[Qgis-user] change project crs
Paulo van Breugel p.vanbreugel at gmail.com
Fri Jul 5 06:13:59 PDT 2013
Yes, but all under the CRS section it is greyed out unless I select 'Enable
on the fly CRS transformation'.
On Fri, Jul 5, 2013 at 1:51 PM, Leyan <ouyang.leyan.ml at hotmail.com> wrote:
> I do not see anything changed, it is still in the "Project properties"
> options for me ("Project"->"Project properties" under Linux). You don't
> have this menu item?
> On 07/05/2013 04:41 PM, Paulo van Breugel wrote:
>  Hi,
>  When I create a new project there does not seem to be the option in the
> project properties to set the CRS to something else then the default (using
> QGIS-master / 1.9 on Ubuntu 13.04). Is that correct?
>  I know it is possible to change the CRS by selecting a layer and use the
> option to set the project CRS from the layer. However, it would still be
> good if one could set the CRS of a new project in the properties dialogue.
> And I thought that used to be possible.. Or am I missing something here?
> Paulo
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130705/86b117b3/attachment.html>
