[Qgis-user] QGIS installation problem with Mac OSX 10.8.4 and some Qt4 Modules
Marcel Stadelmann
marcel.stadelmann at gmx.net
Sat Jul 6 09:07:40 PDT 2013
yeah, there was an old sipconfig.pyc in /usr/local/lib/python2.7/site-packages/ (the results of your instructions see below). After deleting sipconfig.pyc, the python configuration passed, but then i got stacked while "make -j 8". The following failures appeared:
g++ -c -pipe -fPIC -O2 -Wall -W -DNDEBUG -DSIP_PROTECTED_IS_PUBLIC -Dprotected=public -DQT_NO_DEBUG -DQT_CORE_LIB -I. -I/Users/Marcello/Downloads/PyQt-mac-gpl-4.10.2/qpy/QtCore -I/usr/local/include -I/System/Library/Frameworks/Python.framework/Versions/2.7/include/python2.7 -I/mkspecs/macx-g++ -I/Library/Frameworks/QtCore.framework/Headers -I/usr/include -F/Users/Marcello/Downloads/PyQt-mac-gpl-4.10.2/qpy/QtCore -F/Library/Frameworks -o sipQtCoreQXmlStreamNamespaceDeclaration.o sipQtCoreQXmlStreamNamespaceDeclaration.cpp
/Users/Marcello/Downloads/PyQt-mac-gpl-4.10.2/QtCore/sipQtCoreQPyNullVariant_5.cpp:301: error: too many initializers for ‘sipClassTypeDef’
make[1]: *** [sipQtCoreQPyNullVariant_5.o] Error 1
make[1]: *** Waiting for unfinished jobs....
/Users/Marcello/Downloads/PyQt-mac-gpl-4.10.2/QtCore/sipQtCoreQXmlStreamReader.cpp:1856: error: too many initializers for ‘sipClassTypeDef’
/Users/Marcello/Downloads/PyQt-mac-gpl-4.10.2/QtCore/sipQtCoreQXmlStreamWriter.cpp:1198: error: too many initializers for ‘sipClassTypeDef’
/Users/Marcello/Downloads/PyQt-mac-gpl-4.10.2/QtCore/sipQtCoreQXmlStreamEntityResolver.cpp:282: error: too many initializers for ‘sipClassTypeDef’
make[1]: *** [sipQtCoreQXmlStreamReader.o] Error 1
make[1]: *** [sipQtCoreQXmlStreamWriter.o] Error 1
make[1]: *** [sipQtCoreQXmlStreamEntityResolver.o] Error 1
/Users/Marcello/Downloads/PyQt-mac-gpl-4.10.2/QtCore/sipQtCoreQXmlStreamEntityDeclaration.cpp:409: error: too many initializers for ‘sipClassTypeDef’
/Users/Marcello/Downloads/PyQt-mac-gpl-4.10.2/QtCore/sipQtCoreQXmlStreamNotationDeclaration.cpp:349: error: too many initializers for ‘sipClassTypeDef’
make[1]: *** [sipQtCoreQXmlStreamEntityDeclaration.o] Error 1
/Users/Marcello/Downloads/PyQt-mac-gpl-4.10.2/QtCore/sipQtCoreQXmlStreamNamespaceDeclaration.cpp:341: error: too many initializers for ‘sipClassTypeDef’
make[1]: *** [sipQtCoreQXmlStreamNotationDeclaration.o] Error 1
make[1]: *** [sipQtCoreQXmlStreamNamespaceDeclaration.o] Error 1
make: *** [all] Error 2
Am 06.07.2013 um 17:16 schrieb William Kyngesburye <woklist at kyngchaos.com>:
> yeah, something for the old sip was not deleted... try this:
> start python2.7, then:
> import sipconfig
> sipconfig.__file__
Marcels-iMac:PyQt-mac-gpl-4.10.2 Marcello$ python
Python 2.7.2 (default, Oct 11 2012, 20:14:37)
[GCC 4.2.1 Compatible Apple Clang 4.0 (tags/Apple/clang-418.0.60)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
>>> import sipconfig
>>> sipconfig.__file__
'/usr/local/lib/python2.7/site-packages/sipconfig.pyc'
> This should tell you where pyqt configure is finding sip. You can also get the details of that sipconfig:
> from sipconfig import _pkg_config
> _pkg_config
>>> _pkg_config
{'default_mod_dir': '/Library/Python/2.7/site-packages', 'default_bin_dir': '/System/Library/Frameworks/Python.framework/Versions/2.7/bin', 'platform': 'macx-g++', 'sip_version_str': '4.14.6', 'universal': '', 'sip_version': 265734, 'sip_config_args': '--destdir=/usr/local/Cellar/sip/4.14.6/lib/python2.7/site-packages --bindir=/usr/local/Cellar/sip/4.14.6/bin --incdir=/usr/local/Cellar/sip/4.14.6/include --sipdir=/usr/local/share/sip', 'default_sip_dir': '/usr/local/share/sip', 'sip_mod_dir': '/usr/local/Cellar/sip/4.14.6/lib/python2.7/site-packages', 'sip_bin': '/usr/local/Cellar/sip/4.14.6/bin/sip', 'sip_inc_dir': '/usr/local/Cellar/sip/4.14.6/include', 'py_conf_inc_dir': '/System/Library/Frameworks/Python.framework/Versions/2.7/include/python2.7', 'deployment_target': '', 'py_lib_dir': '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/config', 'arch': '', 'py_version': 132866, 'py_inc_dir': '/System/Library/Frameworks/Python.framework/Versions/2.7/include/python2.7'}
> On Jul 6, 2013, at 3:16 AM, Marcel Stadelmann wrote:
>> Hello,
>> I removed everything from homebrew which could cause problems for a QGIS installation. I just left bison and expat in homebrew, for sqlite I was not sure if I can leave it (see below the brew list). Then I installed the required components according the install instruction, Qt 4.8.5, your frameworks (gdal complete) and postgres+postgis extension, spatialindex 1.8.1and sip 4.14.7. I got stacked installing PyQt 4.10.2. This program looks for sip 4.14.6 which is the old (previous) installation (see below). My interpretation is that the sip 4.14.7 installation was not good, although there was no error message. Any idea?
>> Thank you
>> Marcel
>> Marcels-iMac:PyQt-mac-gpl-4.10.2 Marcello$ python2.7 configure.py -d /Library/Python/2.7/site-packages -b /usr/local/bin -n /usr/local/Qt4.8/qsci -v /usr/local/share/sip/PyQt4
>> Determining the layout of your Qt installation...
>> This is the GPL version of PyQt 4.10.2 (licensed under the GNU General Public
>> License) for Python 2.7.2 on darwin.
>> Type '2' to view the GPL v2 license.
>> Type '3' to view the GPL v3 license.
>> Type 'yes' to accept the terms of the license.
>> Type 'no' to decline the terms of the license.
>> Do you accept the terms of the license? yes
>> Found the license file pyqt-gpl.sip.
>> Checking to see if the QtGui module should be built...
>> Checking to see if the QtHelp module should be built...
>> Checking to see if the QtMultimedia module should be built...
>> Checking to see if the QtNetwork module should be built...
>> Checking to see if the QtDBus module should be built...
>> Checking to see if the QtDeclarative module should be built...
>> Checking to see if the QtOpenGL module should be built...
>> Checking to see if the QtScript module should be built...
>> Checking to see if the QtScriptTools module should be built...
>> Checking to see if the QtSql module should be built...
>> Checking to see if the QtSvg module should be built...
>> Checking to see if the QtTest module should be built...
>> Checking to see if the QtWebKit module should be built...
>> Checking to see if the QtXml module should be built...
>> Checking to see if the QtXmlPatterns module should be built...
>> Checking to see if the phonon module should be built...
>> Checking to see if the QtAssistant module should be built...
>> Checking to see if the QtDesigner module should be built...
>> Checking to see if the QAxContainer module should be built...
>> Checking to see if the dbus support module should be built...
>> DBus v1 does not seem to be installed.
>> Qt v4.8.5 free edition is being used.
>> Qt is built as a framework.
>> SIP 4.14.6 is being used.
>> The Qt header files are in /usr/include.
>> The shared Qt libraries are in /Library/Frameworks.
>> The Qt binaries are in /Developer/Tools/Qt.
>> The Qt mkspecs directory is in /usr/local/Qt4.8.
>> These PyQt modules will be built: QtCore, QtGui, QtHelp, QtMultimedia,
>> QtNetwork, QtDBus, QtDeclarative, QtOpenGL, QtScript, QtScriptTools, QtSql,
>> QtSvg, QtTest, QtWebKit, QtXml, QtXmlPatterns, phonon, QtDesigner.
>> The PyQt Python package will be installed in /Library/Python/2.7/site-packages.
>> PyQt is being built with generated docstrings.
>> PyQt is being built with 'protected' redefined as 'public'.
>> The Designer plugin will be installed in
>> /Developer/Applications/Qt/plugins/designer.
>> The QScintilla API file will be installed in /usr/local/Qt4.8/qsci/api/python.
>> The PyQt .sip files will be installed in /usr/local/share/sip/PyQt4.
>> pyuic4, pyrcc4 and pylupdate4 will be installed in /usr/local/bin.
>> Embedding sip flags...
>> Generating the C++ source for the QtCore module...
>> sh: /usr/local/Cellar/sip/4.14.6/bin/sip: No such file or directory
>> Error: Unable to create the C++ code.
>> Marcels-iMac:PyQt-mac-gpl-4.10.2 Marcello$ sip -V
>> 4.14.7
>> Marcels-iMac:PyQt-mac-gpl-4.10.2 Marcello$ which sip
>> /usr/local/bin/sip
>> Marcels-iMac:PyQt-mac-gpl-4.10.2 Marcello$ brew list
>> atk cairo expat gdbm ghostscript gsl imagemagick latex2rtf libpng little-cms2 pixman sqlite
>> autoconf check fontconfig gdk-pixbuf giflib gtk+ intltool libcroco librsvg lzlib pkg-config xz
>> automake cmake freetype geos glib harfbuzz jbig2dec libffi libtiff ossp-uuid proj
>> bison doxygen freexl gettext graphicsmagick icu4c jpeg libgeotiff libtool pango readline
>> Am 05.07.2013 um 19:22 schrieb William Kyngesburye <woklist at kyngchaos.com>:
>>> On Jul 5, 2013, at 12:01 PM, Marcel Stadelmann wrote:
>>>> Thank you for answering. In the meantime i got a step forward. I can successfully cmake qgis (see below), but when i do "make -j 8" it gives quite a lot of errors. The errors look i. e. like this:
>>>> [ 56%] Generating moc_qgsabout.cxx
>>>> In file included from /Users/Marcello/Downloads/Quantum-GIS-master/src/providers/spatialite/qgsspatialiteprovider.cpp:29:
>>>> /Users/Marcello/Downloads/Quantum-GIS-master/src/providers/spatialite/qgsspatialiteprovider.h:393:43: error: unknown type name 'gaiaVectorLayerPtr'; did you mean 'gaiaTextReaderPtr'?
>>>> bool checkLayerTypeAbstractInterface( gaiaVectorLayerPtr lyr );
>>>> gaiaTextReaderPtr
>>> If they're all about spatialite, then this could be an old or incomplete spatialite install (/usr/local) or confusion with the SQLite framework vs. your /usr/local install.
>>>>> Did you have any problems compiling SIP/PyQt after installing Qt 4.8.5? If updating to a newer Qt, did you recompile SIP/PyQt?
>>>> Yes, PyQt did not work with sip 4.14.7 so I installed sip 4.14.6 with homebrew. After reinstalling Qt 4.8.4, sip 4.14.6, PyQt4 4.10.1, QScintilla2 2.7.2 (all with homebrew) and Qwt 6.0.2 (conventional) i can do at least the cmake.
>>> There should be no problems with SIP 4.14.7, PyQt 4.10.2 and Qt 4.8.5 (just tried it myself).
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> Earth: "Mostly harmless"
> - revised entry in the HitchHiker's Guide to the Galaxy
