[Qgis-user] cut several segments into a polygon
    Jake Maier
    j.m at jmforestry.com
    Tue Jul  9 08:13:35 PDT 2013
Thank you Randy,
I did have some trouble with the difference plugin in so far as it seems not
to cut holes into the layer, but instead give me the individual parts. I'm
not sure what I may have done wrong.
Jake
-----Original Message-----
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Bernhard Ströbl
Sent: Tuesday, July 09, 2013 9:47 AM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] cut several segments into a polygon
Hi Jake,
I had a plugin in preparation that amongst others does exactly what you
want: within an editing session cut out from polygons in editable theme with
selected polygons from another theme.
The plugin is called DigitizingTools and is planned to contain more tools in
the future. I uploaded it to the plugin repository just now, feel free to
give it a try and report any problems.
It is marked as experimental (because it is not well tested right now) and
only works with current master (aka QGIS 2).
Bernhard
Am 09.07.2013 15:11, schrieb Randal Hale:
> Hey Jake,
> Here's how I typically add a cut to an existing stand (or depending on
> who you stand in front of - regeneration cut or clear cut).
> 1. Select all of your clearcuts in the stand.
> 2. IN the QGIS menu go to Vector -> geoprocessing -> difference 3.
> Both the input and the difference layer will be the name of your
> shapefile with the stand in it.
> 4. Uncheck "Use only selected features" under Input Vector Layer 5.
> Make sure "Use only selected features" is checked under difference
> layer 6. Create an output shapefile and run.
> You should have a new stand with multiple "holes" cut into it so you
> get the right acreage.
> Randy
> On Tue, Jul 9, 2013 at 7:42 AM, Jake Maier <j.m at jmforestry.com
> <mailto:j.m at jmforestry.com>> wrote:
>     How can I create a polygon with several areas cut out. The cut out
>     areas are all contained in polygons of the same shape file.____
>     I have a large forest stand and contained in it are many smaller
>     stands. ____
>     Thank you for your help____
>     Jake____
>     __ __
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/qgis-user
> Randal Hale, GISP
> North River Geographic Systems, Inc
> http://www.northrivergeographic.com
> 423.653.3611 rjhale at northrivergeographic.com
> <mailto:rjhale at northrivergeographic.com>
> twitter:rjhale
> http://about.me/rjhale
__________ Information from ESET Mail Security, version of virus signature
database 8545 (20130709) __________
The message was checked by ESET Mail Security.
http://www.eset.com
