[Qgis-user] where to install qgis-web-client on Mac OSX 10.8.4
Marcel Stadelmann
marcel.stadelmann at gmx.net
Wed Jul 10 12:59:10 PDT 2013
Hi Andreas,
yes, with the map parameter I could go a step further, the alaska layer appeared. But while trying to import it, the following internal server error was shown:
Kartenabfrage-Fehler [Fehler:Error downloading http://localhost/qgis-mapserv/qgis_mapserv.fcgi?map=/Library/WebServer/Documents/alaska.qgs&&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=-15256791.5967269185930490,482471.5356363095343113,15452694.4898276831954718,30602207.0081926248967648&CRS=EPSG:2964&WIDTH=1084&HEIGHT=1063&LAYERS=alaska&STYLES=&FORMAT=image/jpeg&DPI=72&MAP_RESOLUTION=72&FORMAT_OPTIONS=dpi:72 - server replied: Internal Server Error; URL: http://localhost/qgis-mapserv/qgis_mapserv.fcgi?map=/Library/WebServer/Documents/alaska.qgs&&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=-15256791.5967269185930490,482471.5356363095343113,15452694.4898276831954718,30602207.0081926248967648&CRS=EPSG:2964&WIDTH=1084&HEIGHT=1063&LAYERS=alaska&STYLES=&FORMAT=image/jpeg&DPI=72&MAP_RESOLUTION=72&FORMAT_OPTIONS=dpi:72]
The layer was somehow imported, i.e. i can open the preferences, but no data are shown.
Any idea?
Thank you
Marcel
Am 10.07.2013 um 21:15 schrieb Andreas Neumann <a.neumann at carto.net>:
> Hi Marcel,
> You are missing the project file. Did you read the QGIS server tutorial?
> See
> http://hub.qgis.org/projects/quantum-gis/wiki/QGIS_Server_Tutorial#Map-parameter
> Otherwise the server can't know what project you want to access.
> First you should start with a map parameter - later on, esp. in a
> production environment - you should configure Apache rewriting.
> I don't think that OSX is too different from Linux - it least it is more
> similar than Windows.
> Andreas
> Am 10.07.2013 18:33, schrieb Marcel Stadelmann:
>> Am 10.07.2013 um 16:58 schrieb Andreas Neumann <a.neumann at carto.net>:
>>> Hi Marcel,
>>> If the GetCapabilities command is answering it means that at least parts
>>> of the QGIS server is running ok.
>>> The WMS server supports the following commands:
>>> GetCapabilities
>>> GetMap
>>> GetLegendGraphic
>>> GetFeatureInfo
>>> GetPrint
>>> The GetCapabilities is always at the start of a session or connection to
>>> get the service metadata.
>>> In your case it looks like a CRS issue. You should make sure that in
>>> your new empty test project you specify the same projection as in the
>>> Alaska sample project. There are reprojection options - but for a start
>>> it is easier if server and client are in the same projection. It will
>>> also be faster if no reprojection has to be done.
>> I tried, but no success. After I delete the /Library/WebServer/Documents/alaska.qgs file, still 1 layer was showing up while adding a WMS-Layer. It means the behaviour of the WMS-Connection is the same with or without the project file alaska.qgs. So, it's probably not a CRS issue. It seems that the QGIS Server doesn't see the alaska project file at all.
>> I connect to the localhost with the url http://localhost/qgis-mapserv/qgis_mapserv.fcgi? -> Is this correct?
>> In the QGIS user manual (Chapter QGIS Server) it says that a copy of qgis_mapserv.fcgi is needed for Linux. But how is it for an OSX? I found this file in /Applications/QGIS.app/Contents/MacOS/fcgi-bin/ and put also a copy of it in /Library/WebServer/Documents/. But somehow I don't understand how it works… I afraid my QGIS Server configuration is not correct. But at this point I'm lost.
>> Is there somewhere a documentation for OSX that explains which file has to be in which folder?
>>> Once QGIS works fine as a client, you can go on and configure QGIS web
>>> client. Before, it makes no sense and you should first fix the server.
>>> Andreas
>>> Am 10.07.2013 16:34, schrieb Marcel Stadelmann:
>>>> Hello Andreas,
>>>> I try to do the Alaska example described in the QGIS Documentation, chapter QGIS Server (http://docs.qgis.org/1.8/html/de/docs/user_manual/working_with_ogc/ogc_server_support.html).
>>>> The problem is, that this example is for Linux. On OSX some things seem to be a bit different, especially the paths. I saved the project file with the new project settings in /Library/WebServer/Documents/alaska.qgs.
>>>> In order to test if my QGIS server is running ok, I did two tests:
>>>> 1. In Safari I put the following url:
>>>> http://localhost/qgis-mapserv/qgis_mapserv.fcgi?map=/Library/WebServer/Documents/alaska.qgs&SERVICE=WMS&REQUEST=GetCapabilities
>>>> the browser answers with the following message:
>>>> WMS Test test text/xml image/jpeg image/png image/png; mode=16bit image/png; mode=8bit image/png; mode=1bit text/plain text/html text/xml image/jpeg image/png text/xml svg png pdf text/xml
>>>> alaska -179.843 178.454 48.0545 72.2621
>>>> I thought this means the server is running. No map is shown because I still haven't installed the QGIS client. So far so good.
>>>> 2. In QGIS I wanted to add a WMS-Layer. I connected to the localhost with the following url:
>>>> It shows up 1 layer with ID 0 and name wfslayer, but nothing more. When I select this layer, it is not possible to import it. It says: Kein gemeinsames KBS für gewählte Layer. So, I don't know if my QGIS Server is running ok.
>>>> Marcel
>>>> Am 10.07.2013 um 14:34 schrieb Andreas Neumann <a.neumann at carto.net>:
>>>>> Marcel,
>>>>> Do you mean the layers don't appear in QGIS or in QGIS web client? This
>>>>> is an important distinction.
>>>>> The first means that QGIS server is not installed and configured
>>>>> correctly, the other means that QGIS server is running ok and you have a
>>>>> web client configuration problem.
>>>>> I know - the getting started it is a bit hard, esp. if you are on OSX or
>>>>> Windows where there are fewer users. Most existing users install and run
>>>>> QGIS server on Linux.
>>>>> Andreas
>>>>> Am 09.07.2013 19:21, schrieb Marcel Stadelmann:
>>>>>> Sorry, I don't get it.
>>>>>> I can connect form QGIS Desktop as a WMS-Client to QGIS Server, but the Layers don't appear.
>>>>>> Does somebody know a step by step instruction how to configure a simple example on OSX?
>>>>>> Thanks and regards,
>>>>>> Marcel
>>>>>> Am 09.07.2013 um 18:11 schrieb Bernhard Ströbl <bernhard.stroebl at jena.de>:
>>>>>>> anywhere you like and Apache can access them (on a Linux system file permissions must match, I put them in a subdirectory of /srv/www)
>>>>>>> Bernhard
>>>>>>> Am 09.07.2013 17:59, schrieb Marcel Stadelmann:
>>>>>>>> Where can I see the path to QGIS WMS Server directory? I don't know
>>>>>>>> where to save the *.qgs files, so that the QGIS server can find it.
>>>>>>>> Thanks and regards,
>>>>>>>> Marcel
>>>>>>>> Am 09.07.2013 um 16:36 schrieb Marcel Stadelmann
>>>>>>>> <marcel.stadelmann at gmx.net <mailto:marcel.stadelmann at gmx.net>>:
>>>>>>>>> Hi Bernhard,
>>>>>>>>> Thanks for the answers.
>>>>>>>>> Am 09.07.2013 um 15:20 schrieb Bernhard Ströbl
>>>>>>>>> <bernhard.stroebl at jena.de <mailto:bernhard.stroebl at jena.de>>:
>>>>>>>>>> Hi Marcel,
>>>>>>>>>> the way to call your QGIS server is something like:
>>>>>>>>>> http://localhost/qgis-mapserv/qgis_mapserv.fcgi?map=<path_to_your_map>/yourmap.qgs?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.3
>>>>>>>>>> <http://localhost/qgis-mapserv/qgis_mapserv.fcgi?map=%3Cpath_to_your_map%3E/yourmap.qgs?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.3>
>>>>>>>>>> to get the server's capabilites
>>>>>>>>>> be sure to know the possible requests a WMS server can reply to, see
>>>>>>>>>> e.g. [1]
>>>>>>>>>> The client accesses the server and not vice versa.
>>>>>>>>> Ok, I think I understand the philosophy.
>>>>>>>>>> Steps to do:
>>>>>>>>>> 1) Install QGIS server (done)
>>>>>>>>>> 2) Feed QGIS server with a qgis project (*.qgs file)
>>>>>>>>> I saved a QGIS test project with wms capabilites under
>>>>>>>>> /Users/Marcello/Downloads/test/alaska.qgs
>>>>>>>>> The reply of
>>>>>>>>> http://localhost/qgis-mapserv/qgis_mapserv.fcgi?map=/Users/Marcello/Downloads/test/alaska.qgs&SERVICE=WMS&REQUEST=GetCapabilities
>>>>>>>>> <http://localhost/qgis-mapserv/qgis_mapserv.fcgi?map=/Users/Marcello/Downloads/test/alaska.qgs&SERVICE=WMS&REQUEST=GetCapabilities>
>>>>>>>>> in Safari is:
>>>>>>>>> Configuration file problem : perhaps you left off the .qgs extension?
>>>>>>>>> Does the project path need special permissions?
>>>>>>>>>> 3) access QGIS server from a WMS client (e.g. QGIS desktop) to verify
>>>>>>>>>> it is running and delivers maps.
>>>>>>>>> Isn't it easier to test this with Safari? In QGIS I tried to load the
>>>>>>>>> alaska layer through "add wms-layer". But i couldn't connect to my
>>>>>>>>> localhost. I don't know what url exactly is needed. I tried with
>>>>>>>>> http://localhost/Users/Marcello/Downloads/test/alaska.qgs but its not
>>>>>>>>> working. The message was:
>>>>>>>>> Antwort nicht verstanden. Der wms-Provider sagte:
>>>>>>>>> Eigenschaften-Abfrage gescheitert: Error downloading
>>>>>>>>> http://localhost/Users/Marcello/Downloads/test/alaska.qgs?SERVICE=WMS&REQUEST=GetCapabilities
>>>>>>>>> <http://localhost/Users/Marcello/Downloads/test/alaska.qgs?SERVICE=WMS&REQUEST=GetCapabilities>
>>>>>>>>> - server replied: Not Found
>>>>>>>>>> 4) install and configure QWC, see [2]
>>>>>>>>> Where are this kind of projects normally saved in OSX? I think the QWC
>>>>>>>>> files needs to be saved in the project file (in my case under
>>>>>>>>> /Users/Marcello/Downloads/test)?
>>>>>>>>>> Bernhard
>>>>>>>>>> [1] http://en.wikipedia.org/wiki/Web_Map_Service
>>>>>>>>>> [2]https://github.com/qgis/qgis-web-client
>>>>>>>>>> Am 09.07.2013 13:24, schrieb Marcel Stadelmann:
>>>>>>>>>>> Hi Bernhard,
>>>>>>>>>>> Thank you for answering. On my Mac the Apache server works. The QGIS
>>>>>>>>>>> Server is installed according the Tutorial
>>>>>>>>>>> http://hub.qgis.org/projects/quantum-gis/wiki/QGIS_Server_Tutorial. It
>>>>>>>>>>> also seems to work. When I open the link
>>>>>>>>>>> http://localhost/qgis-mapserv/qgis_mapserv.fcgi? I get the following
>>>>>>>>>>> message from Safari: Please check the value of the REQUEST parameter.
>>>>>>>>>>> Now I try to configure and publish a simple QGIS project. But I don't
>>>>>>>>>>> know where to put the files. I also don't understand how the QGIS Server
>>>>>>>>>>> finds the path to the Web Client, because at the moment I have the
>>>>>>>>>>> qgis-web-client folder in /Users/Marcello/Downloads.
>>>>>>>>>>> Marcel
>>>>>>>>>>> Am 09.07.2013 um 12:52 schrieb Bernhard Ströbl
>>>>>>>>>>>> Hi Marcel,
>>>>>>>>>>>> I am sorry, I do not really understand your question, so I explain
>>>>>>>>>>>> some things, maybe you can reformulate your question and people with
>>>>>>>>>>>> Mac OSX knowledge can help you then.
>>>>>>>>>>>> qgis-web-client (QWC) is a JavaScript program to be run in a browser.
>>>>>>>>>>>> To deliver QWC to the browser of your clients you need a web server
>>>>>>>>>>>> (e.g. Apache). You can put QWC whereeever your web server can access
>>>>>>>>>>>> it. QWC needs QGIS Server (a WMS server), normally you would run QGIS
>>>>>>>>>>>> server on the same machine.
>>>>>>>>>>>> Bernhard
>>>>>>>>>>>> Am 09.07.2013 11:18, schrieb Marcel Stadelmann:
>>>>>>>>>>>>> Hi all,
>>>>>>>>>>>>> I try to install the qgis-web-client on a Mac OSX 10.8.4. But I don't
>>>>>>>>>>>>> understand where exactly I have to put it? I think the
>>>>>>>>>>>>> "/home/web/qgis-web-client" path is not for OSX?
>>>>>>>>>>>>> regards,
>>>>>>>>>>>>> Marcel
>>>>>>>>>> __________ Information from ESET Mail Security, version of virus
>>>>>>>>>> signature database 8545 (20130709) __________
>>>>>>>>>> The message was checked by ESET Mail Security.
>>>>>>>>>> http://www.eset.com <http://www.eset.com/>
>>>>>>>>>> _______________________________________________
>>>>>>>>>> Qgis-user mailing list
>>>>>>>>>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>>> signature database 8546 (20130709) __________
>>>>>>>> http://www.eset.com
>>>>>>>> __________ Information from ESET Mail Security, version of virus signature database 8546 (20130709) __________
>>>>>>>> http://www.eset.com
>>>>>>> http://www.eset.com
