[Qgis-user] OS Mastermap, SQL Server and QGIS
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Fri Jul 12 03:27:21 PDT 2013
Hi Steve,
> As an aside, do you know if the Oracle connector uses the
> user_sdo_geom_metadata table to identify the SRID and extents of the tables?
Not that particular table, not for extents (not sure about SRID). There are
various options for the connector which make things much faster. From the
help:
- *Only look in meta data table* Restricts the displayed tables to those
that are in the all_sdo_geom_metadata view. This can speed up the initial
display of spatial tables.
- *Use estimated table statistics* for the layer metadata Whenthe layer
is setup various metadata is required for the Oracle table. Thisincludes
information such as the table row count, geometry type and spatialextents
of the data in the geometry column. If the table contains a largenumber of
rows determining this metadata is time consuming. By activating thisoption
the following fast table metadata operations are done: Row count
isdetermined from all_tables.num_rows. Table extents are always determined
withthe SDO_TUNE.EXTENTS_OF function even if a layer filter is applied. The
tablegeometry is determined from the first 100 non-null geometry rows in
the table.
Those two in particular speed things up.
Jonathan
On 11 July 2013 16:19, Steven Campbell <s.campbell at poole.gov.uk> wrote:
> Hi Nathan ****
> Thanks for making the change β it is sooo much quicker now to load,
> especially for such a large dataset as Mastermap!****
> Just a quick question though, if I try to connect to a secondary MSSQL
> database, it takes a very long time to find the tables. Generally what I do
> is I open a boundary file table (stored in one MSSQL table) so I can zoom
> in to a small location, and then go to open my Mastermap but the initial
> time taken by QGIS to detect the Mastermap table takes a considerable time
> β once found it is quick to open, pan etc β itβs just the initial
> connection that seems very slow.****
> Thanks again!****
> Steve****
> *From:* Nathan Woodrow [mailto:madmanwoo at gmail.com]
> *Sent:* 02 July 2013 04:02
> *To:* Steven Campbell
> *Cc:* qgis-user
> *Subject:* Re: [Qgis-user] OS Mastermap, SQL Server and QGIS****
> Hey Steven,****
> I have made the change in master now too allow QGIS too look in the
> spatial index table for faster extent loading. Works like a treat.****
> I would still have the geometry_columns table to allow QGIS to find the
> tables quicker but you don't need the max_x, etc stuff.****
> Thanks for the tip.****
> Regards,****
> Nathan****
> On Sat, Jun 29, 2013 at 12:00 AM, Steven Campbell <s.campbell at poole.gov.uk>
> wrote:****
> Hi****
> Does anyone else have significant time delays when trying to open large
> datasets from a SQL database in QGIS? I have uploaded my Ordnance survey
> MasterMap data (coverage is the size of an average English County) and
> although the initial connection to identify the table is very quick, the
> loading of the table (even when zoomed in to a very big scale (i.e. 1:100)
> it takes a very long time to open. Once opened the speed is very quick, but
> getting it to open takes a lot of patience as the application appears to
> hang.****
> On a slightly related topic, if I have connected to one MSSQL database,
> QGIS then struggles if I try to connect to an additional database, again it
> just appears to hang for a considerable period of time (30 minutes or more
> at times), it seems odd especially as the connection to the first SQL
> database is almost instant....****
> Any suggestions as to how I can improve this speed would be greatly
> appreciated.****
> Thanks****
> Steve Campbell****
> GIS Manager****
> Corporate Strategy and Communications****
> Borough of Poole | Civic Centre | Poole BH15 2RU****
> Tel: 01202 633 362****
> Email: s.campbell at poole.gov.uk****
> Website:www.boroughofpoole.com****
> *Think Green! Please Recycle*****
> DISCLAIMER:
> This email and any files transmitted with it may be confidential, legally
> privileged and protected in law and are intended solely for the use of the
> individual to whom it is addressed. The copyright in all documentation is
> the property of the Borough of Poole and this email and any documentation
> must not be copied or used other than as strictly necessary for the purpose
> of this email, without prior written consent which may be subject to
> conditions. Any view or opinions presented are solely those of the author
> and do not necessarily represent those of the Borough of Poole. The Borough
> of Poole reserves the right to inspect incoming and outgoing emails. If you
> have received this email in error please contact the sender by return and
> confirm that its contents have been destroyed. Telephone enquiries should
> be directed to the Borough switchboard on 01202 633633.****
> Qgis-user mailing list
> http://lists.osgeo.org/mailman/listinfo/qgis-user****
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130712/f59276aa/attachment.html>
